mixing uv unwrap and uv texture?
4909
3
1
- zdimaria
- 390 posts
this is something ive never really understood, and was hoping someone could explain.
why, when i have 2 streams of geo, uv unwrap one and uv texture the other, then mix them together, only one of the texures show up?
they are both storing uvs on the vertices so its not that. is this a bug or expected behavior?
i am currently in 12.1.125, but recall this happening since 11.
- zdimaria
- 390 posts
sry, forgot to add hip
uvhelp.hipnc (131.2 KB)
- tamte
- 8579 posts
because on box you have vertex UVs
and on sphere point UVs
if you merge those, vertex attributes have priority
so just make sure your UVtexture for sphere produces vertex UVs (set Apply To to Vertex Texture)
FX Supervisor
Method Studios, NY
- supermac
- 120 posts
hi,
wow.. it’s perfect..
it’s only this little setting..
thank you very much..
Best regards
