multiple flip fluid collision relationships
4415 2 2- sdugaro
- 380 posts
Hi, is it possible to get one fluid to affect the motion of another, but not vice versa? A naive L affect R doesnt seem to work, as this starter hipfile illustrates. While the rbd object affects both (great) im wondering how I might go about getting a “bottom layer” fluid to propagate through a “top layer” fluid. Somehow take the surface field of one fluid and use it to update the collision field of the other? Any masters able to provide some guidance? thanks!
- Solitude
- 373 posts
- sdugaro
- 380 posts
right, so that was my first inclination. thats great if you are able to get enough stability going between the two. In this case I have a fast moving emitted layer that i want rushing across the top of a fliptank without disturbing it too much. I use a ground plane to ensure there is separation between the dynamics of the top layer, but that kills my fliptank. Can i have a ground plane only apply to the emitted fluid and not the tank? Are there ways to combine two flip solvers/objects? write out the bottom fluid and use its vel field to disturb the top top fluid?
