Performance monitor is so very useful for optimizing networks. Is there a way to drill down and display the bottlenecks/stats of a VOP SOP or Volume VOP SOP? maybe it isn't possible with the SIMD processing?
If I throw in a node that creates a warning it seems to show all the VOP nodes in the performance monitor and entries for “Generate VOP Errors,” maybe it is recompiling each frame or something, but perhaps gives a general idea of performance.
If anyone knows a simple way to dig deep into the network and see similar performance statistics for VOP nodes that would be awesome.
thanks!
Performance Monitor and VOPs
2368 2 1- zephyr707
- 57 posts
- symek
- 1390 posts
The difference between Sops and Vops nodes is that Vops aren't Houdini's operators per se. They generate a snippets of code, which combined together into a single shader get executed by SopVOP. Without the code profiler you can't tell the performance of them, specially that a single node could translate to many vex commands.
Do you experience unexpected bottlenecks or slowdowns? The environment like VEX doesn't leave a lot of space for hand optimization (it optimize itself well). There are some particular functions known for slowing things down, but algebraically-wise you can't really harm vex.
hth,
skk.
ps check also new stuff:
http://www.sidefx.com/docs/houdini12.5/ref/utils/vexexec [sidefx.com]
ps Mantra has built-in profiler for surface context: http://www.sidefx.com/docs/houdini12.5/nodes/out/ifd#id626456 [sidefx.com]
hth,
skk.
- zephyr707
- 57 posts
Many thanks, Symek, that makes a lot of sense. My particular case is for a volume VOP, just want to see where I can speed things up and whether my logic can be improved. I was hoping there would be something that could assist in a way similar to the performance monitor or mantra profiler. I seem to remember a PQ or sidefx tutorial that mentioned vop order as being important since it affected the way things were executed, but I can't remember it right now.
I guess I can change things around in the volume vop and rerun the sim to see if performance improves.
Thanks for your help and the links!
