Hey, quick question,
Is there any way to access the value of a specific voxel within a volume vop? I'm not sure exactly how they are stored, but if I want to, for example, set the density value of the current voxel in the volume vop to the density value of a voxel that is 3 voxels up and 4 voxels to the left of the current one, how could I do this?
Thanks in advance.
Accessing a specific Voxel within a volume vop
2362 1 1- Yegor Swarovski
- 1 posts
- old_school
- 2540 posts
If it is a volume convolution you wish, use the Volume Convolve VOP. It has a 3x3 voxel radius.
Volume Sample from File VOP gives you all the control you need. That and looking at the global inputs for the Volume VOP Global Parameters:
http://www.sidefx.com/docs/houdini12.5/nodes/vop/volumevopglobal [sidefx.com]
Note the dPd? input globals.
Gotta love 3 up and 4 left. Somewhat ambiguous don't you say.
You know that volume containers have an orientation and if you rotate it, it's rotated.
Now if you want to support a randomly rotated volume and still want object space coordinates to index, just set two constant vectors, one Z and one up and then march on those two the average of dPdx, dPdy, and dPdz which should get you the voxel distance assuming you have squareish voxels.
