When you try to drag a material from the material palette onto a parameter in the parameters pane, you get this:
The material is added to the existing node selection, as shown by the parameters pane: “2 nodes selected”. The parameters pane also gets pinned.
Is this by design or a bug?
Another issue is, I think if you only drag a material, the parameter's pane shouldn't show the material's parameters, unless you click the material without dragging. This is also how the Operator Tree View behaves.
Is this by design? (Material question)
1250 0 0- animatrix_
- 4521 posts
