Just switched versions from 12.5.427 to 12.5.533, and a file I'd previously saved with 427 is now exhibiting some weird behavior from the Alembic ROP: it writes what appears to be a single frame of object pivots, rather than the entire animated geometry.
Has anyone else noticed this? I've attached a hip file - works in 427, doesn't work in 533.
alembic ROP broken in 12.5.533?
2748 4 2- meeotch
- 33 posts
- kni8_2k
- 18 posts
- ripclaw
- 96 posts
Sounds similar to a bug I've reported - which has been fixed in build 550 though.
In that bug, there were cases where an Alembic Archive's “Frame” parameters were not keyed correctly to “$FF” but instead just to a single frame. So any animation would just be stuck at that frame, regardless of the timeline. Like I said, in build 550 this appears to be fixed.
- meeotch
- 33 posts
- ripclaw
- 96 posts
