It has been a while since I've got my hands ‘dirty’ with Houdini so please excuse me if this is an obvious one.
I've imported an FBX scene into Houdini which has numerous individual assets in it, some of those assets have there transform messed up, the pivot appears to be in the correct location but the geometry is offset randomly.
Most of the assets are fine this just happens on a few.
Could someone please point me in the right direction on how to fix this?
many thanks up front for the help.
cheers
Andre
Messed up transform for imported FBX
4104 4 2- athomas
- 51 posts
- neil_math_comp
- 1743 posts
This is just a wild guess, and probably not at all the issue, but do the assets that are broken use the “Segment Scale Compensate” option from Maya? Starting in Maya 2010, they both mark the use of compensation *and* bake in the compensation, so our support for it was broken, because we would add in the compensation and compensate for the compensation, undoing it. That's fixed in H13, but there are many things that could be wrong with transformations in the FBX importing, so that's probably not it.
- athomas
- 51 posts
- neil_math_comp
- 1743 posts
athomasYeah, then it's not the Segment Scale Compensate issue. They changed the exporter in Maya *because* Max couldn't support it unless it was baked in.
created in Max not Maya
Not sure if this helps, when I import the whole scene into Unity all transforms are fine.It's good to know there's another source validating the scene. If you can, it'd probably be worth submitting a bug. I hope that I can do something about it, but I can't make any promises.
If you can't submit a bug, is there any animation on the broken assets? How complicated is the transform hierarchy? Any unusual transform orders? Deformation?
- athomas
- 51 posts
