It seems the H11 scene render mode is not available in the latest Houdini13?
Is there a way to get it back? the GL mode is just not stable.
Why H11 scene renderer is not available in Houdini 13?
4950 10 1- oat
- 479 posts
- anon_user_37409885
- 4189 posts
- oat
- 479 posts
- oat
- 479 posts
the images below show the problem with Houdini 13 scene renderer using the same file and the same olt.
image 1:
In Houdini 13, using GL1.1 scene renderer, the colors are totally different from the one in image 3 which is shown in Houdini 12 using H11 scene renderer (both in infra-red color scheme)
image 2:
In Houdini 13, using GL1.1 scene renderer, the primitive attribute values are not even shown in the Details panel.
image 3:
In Houdini 12, using H11 scene renderer, the correct display of color
I'm not sure if it's a problem with my graphic card or Houdini 13.
pls advise!
image 1:
image 2:
image 3:
pls advise!
- 4189 posts
Yeah - H11 is now deprecated and the if you hconfig -H you can see it will be removed. i.e.:
HOUDINI_OGL_H11_VIEWPORT
Enables the H11 3D viewport renderer. This renderer is deprecated and is
going to be removed in the next major Houdini version.
Try putting this in the environment variable:
HOUDINI_OGL_H11_VIEWPORT = 1
You should get the Scene Renderer as in the attachment. This is on OsX.
Can you send a bug report in, just incase the developers dont see your post
- Anonymous
- 678 posts
MartybNz
You can set an environment variable to bring it back
10 Reasons Not to Bring Someone Back from the Dead:
http://io9.com/5916491/10-reasons-not-to-bring-someone-back-from-the-dead [io9.com]
- halfdan
- 599 posts
oatHave you tried using the GL3.3 mode? You have a card capable of using it. GL1.2 is only for remote desktop work, or machines with software GL only. I'd expect it to be buggy, since there's almost no work/fixes being applied to it, due to its extremely limited use.
Halfdan Ingvarsson
Senior Developer
Side Effects Software Inc
Senior Developer
- malexander
- 5161 posts
mantragoraAnd the important 11th, once something is relegated to environment-variable status, you can expect it to be gone shortly thereafter. It is only still available to help people port old H11 GR render hooks to the new GR render hooks.
The H11 renderer doesn't render the new DOP based POPs, packed primitives, alembic primitives or VDBs, so there is very little reason to continue to provide it.
If you run into a showstopping GL viewport issue, please submit a bug so it can be resolved.
- Anonymous
- 678 posts
- edward
- 7734 posts
oat
That difference almost just looks like a gamma difference to me. H13's viewport defaults to a 2.2 display gamma now, which might explain this. Try checking from the main menu > Edit > Color Settings.
- oat
- 479 posts
