I'm writing a script to create points in the centroid of selections of primitives (viewport selection that is). I want to be able to test if the selections are connected, loop through the connected groups and create one centroid for each, but I can't figure out a way to do so.
Is there a way to test the connectivity in python?
I know I could do a similar task with a connectivity SOP and a handful of other nodes, but I wanted to be able to do the whole trick in one single python operator, if possible, that is…
Cheers
Connectivity test in python
3299 5 1- rafaels
- 696 posts
Toronto - ON
- graham
- 1908 posts
Unfortunately there no basically no useful topology information functions exposed in HOM. You basically have to process all the geometry and build the connectivity information yourself and then do what you want with it. That or use inlinecpp to build your own functions that provide access to more useful underlying GU_Detail functions.
- rafaels
- 696 posts
hmmm… and what is hou.GeometrySelection.connectivity() supposed to do?
Toronto - ON
- graham
- 1908 posts
- rafaels
- 696 posts
yeah… there's a lot of stuff undocumented, so frustrating!
Thanks though, knowing what's not possible is a great help!
Toronto - ON
- Cetras
- 41 posts
I had a similar problem not so long ago, and actually I did a cutom python node which list all your selected prims, then all points in these prims (find prims() then vertices() then points() )
Then save all that in a list of points for each prims, then compare points for each prims and if points are found in common then merge prims into a group …
But I'm quite sure there is something to do with that hou.GeometrySelection.connectivity() yes
My portfolio : www.guillaume-j.com
