Hi there, I'm creating a digital asset which will be a Sop operator, but I have a problem. An attribute inside the asset references to a node at the scene level so I'm not able to encapsulate it into the asset.
I've tried to move this node inside but it messes up my attribute. It needs to stay at the scene level.
My question is: is there a way to create a digital asset which, when created, automatically creates this node at the scene level?
Thanks in advance
Digital asset creation problem
1795 2 1- leota
- 21 posts
- rafaels
- 696 posts
Totally! in the scripts tab of your digital asset you can create an onCreated script and make it happen. You might find yourself scripting a lot to manage your nodes later on (e.g. what happens if the user creates two instances of your asset? Do they each create their companion nodes? What happens if the user deletes the companion nodes?), but it is possible. You can also let the user manage the required nodes by themselves if you create companion assets instead.
Cheers
Cheers
Toronto - ON
- leota
- 21 posts
