I have been following along with a tutorial to create a dust devil.
I have no issues using a DOP I\O Node to cache out my geometry as .bgeo files, but I would like to export the scene using Alembic.
I know that I cannot use Alembic Export in Apprentice, but I would like to know how to wire it all up for this particular scene setup for the future as I like the workflow that it uses.
I've attached the project for someone to have a look at if they don't mind
Trouble exporting to Alembic
5370 9 1- Josh Oram
- 43 posts
- anon_user_37409885
- 4189 posts
- Josh Oram
- 43 posts
- 4189 posts
- Sadjad Rabiee
- 1391 posts
Josh Oram
How about exporting groups created by Voronoi fracturing “inside & outside groups”? They don't seem to export even though the geometry exports fine
If you wanna export your Alembic file with included group's like “Inside” and “Outside” , You should export your scene via Export menu instead of “ROP Alembic Output” 8)
- 4189 posts
Joker386
What is the advantage of the Export menu? It just creates an Alembic Output driver which is also Rop Alembic Output node.
Groups also export via the Rop Alembic Output.
- Sadjad Rabiee
- 1391 posts
MartybNzJoker386
Oooops !
Yes you right ,I was wrong and that's no different
- 4189 posts
- mark
- 2593 posts
- 4189 posts
