Grouping primitives with an expression
   1476   2   1
Hi, so I'm new to Houdini and I have a question.
I see that in the group node you can ‘group by expression’. Consider a polygon mesh. Could you create a group that selected primitives/faces based on the number of points it has? So for example selecting all primitives that have more than ‘n’ points? If so what would that expression look like?
I don't know if this is a big ask or something ridiculously simple, so any help would be appreciated!
you can use $NVTX variable which will return number of vertices that of each polygon
so code like this
$NVTX>4
will select all primitives with more than 4 vertices
FX Supervisor
Method Studios, NY
What a champion! Many thanks.
