I used Model–> Shatter and I want to have the chunks of the mesh all move outward from the center of the mesh.
I also do not want the chunks to scale at all.
Any ideas how to get the pieces to all break outwards?
Shatter outward from center
1666 1 1- jbartolozzi
- 58 posts
- goldleaf
- 4177 posts
If you want an outward motion, you just need to apply some outward-facing velocity to the pieces before they feed into DOPs.
If you're trying to get control over a radial distribution of fracture points, you just need to feed some radially-distributed points into the fracture sop.
Here's a hip file to demonstrate both of these, since you didn't post a hip file showing where you're at so far.
Hope this helps!
Hope this helps!
I'm o.d.d.
