Hiya!
Is there way to define a wildcard pattern which merges objects recursively from all “depths” in a subnet hierarchy?
for example something that would pick up all “OUT_RENDER” nodes from all of the following paths:
/obj/subnet1/geo/OUT_RENDER
/obj/subnet1/subnet2/geo/OUT_RENDER
/obj/subnet1/subnet2/geo2/OUT_RENDER
/obj/subnet1/subnet2/subnet3/geo/OUT_RENDER
/obj/subnet1/subnet2/subnet3/subnet4/geo/OUT_RENDER
…etc…
…so somethin like using the bash globstar syntax “/obj/**/OUT_RENDER” - is this possible somehow?
Object merge recursive object path pattern
3395 2 0- olliRJL
- 72 posts
- tamte
- 8554 posts
AFAIK you can do it by specifying finite number of levels, each level separated by whitespace like this
/obj/subnet1/*/OUT_RENDER /obj/subnet1/*/*/OUT_RENDER /obj/subnet1/*/*/*/OUT_RENDER /obj/subnet1/*/*/*/*/OUT_RENDER etc
or maybe doing python Node.glob() to get all nodes you are interested in and output the list of them
(is there any reason for having so many nested Object Level subnets? as they are not necessary for parenting I can imagine that they were created by importing FBX or Alembic at default settings, which I find very unintuitive, but note that you can just uncheck Import Null Nodes as Subnets to get clean hierarchy
similarly for Alembic uncheck Build Hierarchy Using Subnetworks)
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- olliRJL
- 72 posts
Actually I'm not the biggest fan of deep subnet hierarchies either
This “subnetted hierarchy” would be actually coming from reading in a custom “location set” file which brings in a hierarchy of pontentially hundreds to thousands of element assets. Somehow managing this many objects in a flat hierarchy using parenting feels a bit messy compared to subnetted hierarchy.
I'm looking for sort of a best of both worlds solution where I could on the interactive object side keep everything in a neat hierarchy but on the render side merge all the alembic prims into single geometry and use the path attribute for allkinds of handy procedural access to the geometry.
