I'm starting to learn Houdini, and trying to play a little bit with voronoi fractures.
I'm having a little problem with the generated poly at edge.
I'm creating a poly box and scattering points, then fracturing. Up until that it works fine, but on the fractured object appears some “shading artefact” (will call them that lacking a better description).
It's already seen in the viewport, no need to render, but it's of course on the renders also…
See attached jpg.
Beveling the box before fracturing reduce but not make the problem disappear.
I'm surely missing something here, but it's beyond my current Houdini knowledge.
Please help
Voronoi fractured poly shading problem
6377 5 1- Jean-Luc Gason
- 15 posts
- old_school
- 2540 posts
- Jean-Luc Gason
- 15 posts
- Nima
- 471 posts
- old_school
- 2540 posts
NimaNolanDisplay your Primitive normals and make sure the primitives are facing outward to match the outside group primitives.
in simulation color, inside of each piece of fracture is black!
how can change color?
thank you.
If not, reverse the inside primitive group.
- Nima
- 471 posts
