COP artifacts
4479 5 1- jjstanley
- 124 posts
I am trying to comp a few tga sequences and they always have randomly colored artifacts. The colored blocks seem to be completely random as cooking the same frame twice will often give different blocks. I have tried every setting I can fine. Some settings are better than others but none seem to make them go away. Any ideas?
- JColdrick
- 4140 posts
Need more information, like the platform/version you're running on, hardware you're running, the version of Houdini, if you can repro with formats other than tga, if you can repro with a very simple network(such as literally comping one seqence OVER another) or if you need certain COPs to trigger it…
etc etc…pls post details folks!
It sounds like problems with your graphics card/driver, off the top of my head. I use targa all the time without problems…
J.C.
J.C.
John Coldrick
- malexander
- 5158 posts
- jjstanley
- 124 posts
- jjstanley
- 124 posts
- JColdrick
- 4140 posts
As Mark says, you should upgrade your version of Houdini…what you're running has indeed got problems. It's not related to targa - it's buggies. Unfortunately, the card you're using could also be giving you troubles elsewhere - as I recall that was literally the very first nvidia card with a GPU! Anyway, that's probably not related to this problem…
J.C.
J.C.
John Coldrick
