KDE 3.3a
   7225   6   2
Probably old news but kde 3.3 came out!
Anyone know how houdini and suse9.1 get along with it?
soho vfx
I'm not going to risk it. From what I've heard, though, it seems to run fine for the most part, with some nice new features. I doubt it would affect Houdini adversely.
This time, though, I'm letting someone else try it first…
J.C.
John Coldrick
I was thinking the same thing
Curious if it cures that maximize/resize problem….
soho vfx
I'm running KDE 3.3.0 on Gentoo ~x86, and Houdini seems to be working alright, and minimize/maximize seems to work properly.
NTmatter2, can you describe KDE 3.3 setup/update process?
I attempt to update KDE 3.2 to 3.3.
The necessary packages are prescribed in /etc/portage/package.keywords, but errors appear.
bash-2.05b# emerge -uD kde
Calculating dependencies
!!! Problem in kde-base/kde dependencies.
!!! “Specific key requires an operator (kde-base/kdebindings-3.3.0) (try adding an ‘=’)”
and
bash-2.05b# emerge -uD /usr/portage/kde-base/kde/kde-3.3.0.ebuild
Calculating dependencies \Traceback (most recent call last):
File “/usr/bin/emerge”, line 2528, in ?
retval,favorites=mydepgraph.select_files(myfiles)
File “/usr/bin/emerge”, line 865, in select_files
if not self.create(,None,“–onlydeps” not in myopts):
File “/usr/bin/emerge”, line 825, in create
if not self.select_dep(“/”,mydep,myparent=mp,myuse=myuse):
File “/usr/bin/emerge”, line 962, in select_dep
myeb=portage.portdb.xmatch(“bestmatch-visible”,x)
File “/usr/lib/portage/pym/portage.py”, line 4699, in xmatch
myval=best(self.xmatch(“match-visible”,None,mydep,mykey))
File “/usr/lib/portage/pym/portage.py”, line 4710, in xmatch
myval=match_from_list(mydep,self.xmatch(“list-visible”,None,mydep,mykey))
File “/usr/lib/portage/pym/portage.py”, line 4696, in xmatch
myval=self.gvisible(self.visible(self.cp_list(mykey)))
File “/usr/lib/portage/pym/portage.py”, line 4806, in gvisible
if db.dbapi.xmatch(“bestmatch-list”, mykey, None, None, ):
File “/usr/lib/portage/pym/portage.py”, line 4703, in xmatch
myval=best(match_from_list(mydep,mylist))
File “/usr/lib/portage/pym/portage.py”, line 3537, in match_from_list
raise KeyError, “Specific key requires an operator (%s) (try adding an ‘=’)” % (mydep)
KeyError: “Specific key requires an operator (kde-base/kdebindings-3.3.0) (try adding an ‘=’)”
What they do indicate and as correct to establish KDE 3.3?
f = conserve . diffuse . advect . add
fx td @ the mill
If you're upgrading, you can just do
emerge sync
emerge -DUupv world to see what will be merged, and emerge -DUuv world to do the actual upgrades. Most of the time, this will go without a hitch. Of course, it'll take a rather long time to update everything, which is the nature of Gentoo
Judging by the error you've got, I think that you've either got an outdated version of portage that is having trouble with changes to the structure of the ebuild, or an old ebuild with some bugs in it. Just try the procedure outlined above, and see if anything happens.
Oh… I have minimize/maximize problem with KDE 3.3.0 too
fx td @ the mill
