just an easy question (i think)
i have a explosion set up in houdini but need to delay the explosion is there an easy way to do this?
set time on pyrosolver
3022 7 1- rossl
- 105 posts
- Nima
- 471 posts
- rossl
- 105 posts
- rossl
- 105 posts
- Eckxter
- 61 posts
- rossl
- 105 posts
- EvelynRosas
- 1 posts
- Eckxter
- 61 posts
Usually you just change the Start Frame on the DOP Net.
Then inside the DOP Net, on the smoke object, try checking on “Solve on Creation Frame”.
Make sure your source is actually there on the frame you need it.
And check if your container is where your source is.
Or if you're not sure, share you .hip file and I'll have a quick look.
- A little nonsense now and then, is relished by the wisest men.
