I noticed when I use two transform nodes, with both centroid() as pivot, that the second pivot jitters during rotations.
How one would go about fixing that?
Thanks in advance.
Ryuji
Centroid jittering
1817 2 0- 隆二 泉
- 14 posts
- edward
- 7722 posts
As I recall, the centroid() expression gives the center of the bounding box, so it can jitter when you rotate the geometry. If want the average of all the point positions, then perhaps you can use the AttribPromote SOP for “P” (the position attribute) from a point to a detail attribute. Now you can use a detail() expression to access this centroid.
- 隆二 泉
- 14 posts
