Please watch attached video. There is an issue with the FLIP fluid render.
I'm using mantra. Any idea what's wrong?
FLIP render problem
2808 7 2- 5DN
- 152 posts
- Lewul
- 250 posts
- 5DN
- 152 posts
- Sadjad Rabiee
- 1391 posts
- 5DN
- 152 posts
- Lewul
- 250 posts
- Sadjad Rabiee
- 1391 posts
If you used Flip Simulation , then you can export VDB mesh of the fluid to bgeo files .
The Flip Shelf Tool create 3 network : AutoDopNetwork , …_fluid , …_fluidinterior
You should export these bgeo files with ROP Output Driver in the “…_fluid” after VDB nodes (from RENDER node).
Because these files are so large , so you should just export 2 or 3 frame for us :wink:
- 5DN
- 152 posts
