is there any way? or do i have to enable every added point one by one?
i assume there´s a way, no two ways, but i missed both of them.
thanks
fuat
AddSop - enable all points at once?
4523 4 0-
- fuat
- 650 posts
- tamte
- 9432 posts
- fuat
- 650 posts
works like a charm, thank you very much Thomas.
but now that i know, i wanna understand what i did (new to Houdini):
1. when hovering mouse-over the checkbox tick in the params, i realized that the tick´s param (corret me if i am wrong and its not a param) is called “usept” - but what does that stand for?
2. in general, is there any overwiew of all those params so i dont have to mouse-over and let go all the entries ony by one? or is this unneccesary to do?
i checked the help but couldnt find any.
thanks again
fuat | AixSponza
EDIT: i had an inspiration - it stands for “use point”. tadaa.
but question #2 still remains…
thanks again
fuat | AixSponza
Edited by - July 23, 2014 05:28:36
Fuat Yüksel
- mandrake0
- 655 posts
the tip from tamte:
the usept* is a filter expression that means it will show all the parameter value from the node with this parametername.
this case: usept0, usept1, usept2, usept3 ……
you can hover over with the mouse the activate / deactivate parameter from the point and you will see the parametername usept0 or a other value.
2. select node and RMB => Edit Parameter interface there are the parameters in the Parentheses or RMB => Animatable Parameters
- fuat
- 650 posts
mandrake0
the tip from tamte:
thank you, mandrake.
the first one i found out already like mentioned, and for the second answer, i didnt know the animatable params. good to know.
fuat
Fuat Yüksel
