How do I import a custom renderman shader that I have written?
-jon
importing renderman shader?
3037 1 1- vrljc
- 63 posts
- JColdrick
- 4140 posts
In Houdini 7, take a look in the help in Outputs/Renderman Rendering/Renderman Setup, rather than someone rewriting all the existing docs. Lots of good information in there that you'll need to know. Essentially your rman shader path needs to be setup properly, and you can use “rmands” to create dialogs for use interactively in Houdini.
Note you must have Houdini Master to do this - Apprentice doesn't run rman shaders.
J.C.
J.C.
John Coldrick
