Hey guys.
I have a problem.
For the last while I have been making extensive usage out of the copy sop but I think I will have to make use of the for each sop in a way that I havent yet had the chance to.
So I make use of stamping inside the copy sop all the time, and I find it simple because it separates the variable, the function, and the calling of the variable. It makes sense.
However when I want to create a fit01 expression on a subdivide depth on every for each instance using the stamping function I am finding it confusing as to why it is not working out.
What I am trying to do is make a grid of a few divisions( say, 3x3 ) ( polygons ).
use connectivity/partition to split the primitives up, and assign a colour/group. ( I do this because I can separate by colour, which I can paint, or use Vops/textures )
Then inside the for each I split up every poly based on colour.
On every polygon I want a random subdivision depth, and I am guessing I will have to make use of stamping/ some expression to make it random for each piece )
Any thoughts?
EDIT, I got it working using this expression,
opdigits(stamps(“..”, FORVALUE, “”))
But what I am hoping to get is a random 0,1 value for each poly/group in the depth value of the subdivision node.
forEach stamping
4430 6 2- ambient-whisper
- 53 posts
- Sadjad Rabiee
- 1391 posts
- Sadjad Rabiee
- 1391 posts
- Sadjad Rabiee
- 1391 posts
- ambient-whisper
- 53 posts
- animatrix_
- 4516 posts
ambient-whisper
Thanks a ton Looks like I wasnt wrong when experimenting with expressions. I just had to use forIDvalue and not forvalue. That was the only thing that made the difference.
Also bear in mind that if you have 2 nested ForEach SOPs, you have to rename them to make sure they are not using the same names for FORIDXVALUE and FORVALUE. Otherwise you will waste a lot of debugging efforts.
I heard that the users should be responsible for this but I think this is a bug. Even if it wasn't, how could you know what a locked 3rd party HDA is using for these parameters when you have to use it inside a ForEach SOP?
Thought I would point this out so you save some time
youtube.com/@pragmaticvfx | patreon.com/animatrix | animatrix2k7.gumroad.com
- Kfinla
- 99 posts
I have a similar issue, that I think a foreach is the way to solve but so far no luck.
I am basically trying to find the closest vert/ ray intersection for each of a number of objects copied along curve. I can find the closest point and copy “one” object to that location, but I can't seem to solve how to find the closest point for each object relative to it.
I think the issue really at the moment is finding the closest point in each rayhitgroup, vs. at the moment I am seeing all the ray hit groups made by all the objects and then culling away all but the smallest value overall, not relative to each object.
Any ideas? different approach?
** Never mind, I sorted it out. I was trying to do too much in the foreach, and broke it down to just the ray hits, plus a group mask.
