Lines To Tubes?
   9662   3   0
Hi All,
I have a scene that generates lines. I want to convert those lines into thin tubes.
What series of nodes would I use?
I thought I could just use a sweep with a circle, but that did not work?
I am attaching my scene and the screen shot has some highlight where I am trying to implement the lines to tubes.
The squared off white lines you see in the render are the graphic elements I am trying to turn into tubes (i.e. I want to make them thinner).
This scene is basically the tutorial found here:
https://vimeo.com/41667113 [vimeo.com]
Edited by - Nov. 13, 2014 15:08:48
Screen Shot 2014-11-13 at 2.59.32 PM.png (478.7 KB)
ap_font_profiles_1b.hipnc (2.4 MB)
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
try polywire
Training Lead
www.sidefx.com
Thanks, PolyWire did the trick. It gave me a radius I could lower to make a thin line.
I am seeing some normal shadowing on the ends of each line, however. Is there a technique for cleaning that up?
Also I have tried subdivide on the font node but I still have a fairly block font.
Try adjusting the Level of Detail on the Font SOP.
