Hello, What is the best way to proceed for profiling the code? I'm using the built-in profiler in VS2010 without no luck. When I start the profiling session (CPU sampling) the report is showing me the time Houdini spends in all the dlls, like the graphics drivers, or the opengl driver, instead of showing me the time spent in each function of the custom plugin.
When doing the instrumentation, VS opens Houdini with the default scene. That's it.
I could use the random-pausing technique but the code ends so fast (0.1 s) that I'm unable to get any useful sample.
Unfortunately, I haven't found any post related to profiling code here.
Thanks in advance
Profiling the plugin.
2099 3 1- pedro3145
- 41 posts
- edward
- 7735 posts
If you have fast code like that, especially if during node cook, then you might want to consider making your cook much longer, say by looping it a few thousand times. Secondly, make sure you built your plugin with symbols (make sure that you're using the -Z7 or -Zi compiler option).
I've never used VS2010 for profiling but I've had moderate success with VS2012 with the win64-vc11 build. I've also used GlowCode in the past but version 8.0 was the last one I had.
- pedro3145
- 41 posts
edward
I just found the way without using symbols* applying the infinite monkey theorem.
Go to:
Analyze -> Profiler ->Attach/Detach -> Select the houdini.exe
Cook the SOP (few frames)
Stop profiling
The report is bloated is with an infinite, unnecesary amount of dlls (this is why I couldn't find the function), doubleclick the one that has cookmySOP (if you can find it).
That's it.
Hope this helps.
*(btw the hcustom -d command doesn't print -Z7 -Zi, I used -Zc:forScope)
- Anonymous
- 678 posts
pedro3145
Yes it does, but to see them you need to specify correct flags to print output flags for debug mode. See this topic => http://forums.odforce.net/topic/17885-visual-studio-startup-project/?gopid=108460#entry108460 [forums.odforce.net]
