I have a file a friend sent me to debug. The first thing I noticed is he has about 50 pop networks and each of them has an incorrect reference in the source pop /impulserate parameter.
Since his popnet1 needs to reference an object called…/sort1, I figured I should write a little script to go in there and fix the bad paths for him.
So far I have this:
for i = 1 to 21
chrmkey -t 0 /obj/geo1/break_shit/popnet${i}/source${i}/impulserate
chkey -t 0 -v 0 -m 0 -A 0 -F ‘nprims(“/obj/geo1/break_shit/sort${i}”)/1’ /obj/geo1/break_shit/popnet${i}/source1/impulserate
end
This works great except for one thing… it puts this into the parameter:
What I want it to do, is for each {i} put the value in its place like so:
nprims(“/obj/geo1/break_shit/sort1”)/1 (where the 1 in sort1 is sort${i} evaluating for the first time.
Obviously it's the chkey command followed by the string designated by the ticks `` that's throwing this off. But how do I get around this?
Scripting Q
3111 3 0- the_squid
- 132 posts
- edward
- 7754 posts
- the_squid
- 132 posts
Here's what it puts into my Impulse Birth Rate when I do what's been recommended:
nprims(“/obj/geo1/break_shit/sort`${i}`”)/1
Notice the ticks remain intact – not exactly what we wanted :wink:
The problem is I'm entering a string into a parameter using the chkey command. chkey allows you to set a key, set the frame for the key, and set the value for the key. In this case I'm setting a string instead of a value, so I have to indicate that it's a string by using the ``
Once I do that, it's no longer evaluating the section within the ``'s as part of my “for each” loop.
- the_squid
- 132 posts
SOLUTION FOUND!
for i = 1 to 21
chkey -t 0 -v 0 -m 0 -A 0 -F ‘nprims(“/obj/geo1/break_shit/sort’${i}'”)/1' /obj/geo1/break_shit/popnet${i}/source1/impulserate
…So something I did during my last post mustve been wrong… and Edward gets kudos for having the solution all along
for i = 1 to 21
