Hi Members,
Is there any solution to automatically run a script and get the actually opened hip file name when it happens in Houdini. In XSI there are events for scripting purpose.
THANKS,
Szabi
Event when Hip is Opened
4635 6 1- Gemini4147
- 13 posts
- mandrake0
- 637 posts
whats the target? and when you need the filename?
when it's for start up you can make a custom function or a variable?
http://odforce.net/wiki/doku.php?id=startupscripts [odforce.net]
the file variable you can check under Edit > Aliases and Variables …
$HIP or $HIPNAME
houdini is not same as softimage or maya where you can view every command.
if you wan't to know more look at this post from jeff:
http://forums.odforce.net/topic/17105-short-and-sweet-op-centric-lessons/#entry104263 [forums.odforce.net]
$HIP or $HIPNAME
- Gemini4147
- 13 posts
- mandrake0
- 637 posts
some time ago i wanted to make a project manager in houdini where you can manage the project folder layout with all the shots, light, geo setup. more like a sequenzer where you insert your shot and you can add light, terran presets that will add automaticly in that houdini shot.
know it should be possible that's to the pyqt binding, i will see what i can do….
- Platon
- 99 posts
Illés Szabolcs
Hi Members,
THANKS,
Szabi
seems like you are looking for 456.cmd or 456.py
https://www.sidefx.com/docs/houdini13.0/commands/_guide [sidefx.com]
it gets executed on scene open.
- Szabolcs Illés
- 1 posts
- sorian
- 49 posts
