parsing files with VEX
   6171   7   1
Hey guys, I think I may have actually asked this on a now locked and invisible thread so I thought I would ask it again, especially with all the cool new string operations in H14 vex:
what is the best way to operate on lines on a file in vex? I basically want to create a point for each line on a file based on some parameters in the line, i.e:
13.5 44.7 4.6 0 255 128 128
where the format is x y z i (intensity) r g b
thank you!
-G
… which do not yet exist. We pulled out most of the file_ operations pending further internal testing, but it seems the documentation did make it in.
He he he I was wondering why I did not see them on the new features section the other problem I have is that, ideally, I can parse multiple lines of the file at once in parallel via simd (the reason why I wanted to use vex) I presume I would have to put it in a string array attribute first? (Would it work with 100 mil lines?)
Thank you guys!
-G
Currently you need to do a systemRAW() expression on a string field, then you can chs() into VEX.
You won't get SIMD processing then, however. It is hard to set that up currently without there being an O(n^2) component that will eliminate the advantage of SIMD actions…
I've done this with some large files, but I don't think 100 million.
mhhh.. perhaps the time has come to write my first HDK node its only been 5 years or so…
-G
grayOlorin
Before you go whole hog C++, maybe you could investigate a Python SOP
You might want to look at the Python source for the Table Import SOP.
when will be the vex file operators released?
i made a simple vex based stl exporter and it would be cool to test it on big meshes. :-)
or are there other possibility's for reading the string values in python?
