The title is actually pretty clear.
I was playing around with this stuff and espacially with liquid sims my machine quickly is overchallanged. I'd say that somewhere around 10 million particles is my machines max, beyond that even canceling the sim can take 30 minutes or longer. All over the www thare videos of artists showcasing their sims with, I don't know, 15, 20 even up to 30 million particles.
What kind of machines do they have?
What hardware is important for a powerful machine, concerning liquid sims in particular? CPU, RAM, graphics card, all?
…and how dense should a highres sim be? What is highres and what lowres? I mean when your working at a big studio, where you can simulate your scene on a farm, 10 - 20 million particles might be lowres but for the avarage human, what resolution seems to be appropriate?
What system resources do fluid/liquid sims need?
10111 9 1-
- anon_user_21411066
- 210 posts
- anon_user_89151269
- 1755 posts
- 210 posts
- mandrake0
- 655 posts
- 210 posts
- goldleaf
- 4259 posts
While more RAM is always great, that doesn't always magically make everything faster. Your CPU speed, Hard Drive, and Graphics Card have a huge impact as well. Have you confirmed that you're running out of memory in the Task Manager? If you can get an SSD, that should help too. And Houdini under Linux is much more efficient. Make sure your graphics drivers are up to date.
As far as density of particles, it totally depends on the shot; Igor posted some tests on Vimeo a year or so ago (H13), this gives you an idea of scale: https://vimeo.com/86802065 [vimeo.com]. And his workstation specs in the comments were:
So he was simming 16million particles in ~7 hours on that machine. Also remember, your collision geometry can have a huge impact as well (if it's deforming uncessarily or if its way more detailed than needed).
Hope that helps inform expectations a bit!
On every video that i posted peopls ask for workstation spec, its 4-5yearts old
I7 950 3.05Ghz
24GB 1333Mhz
8800GT 512MB ram
Ubuntu 12.04
I'm o.d.d.
- 210 posts
goldleafReally, the graphics card has an impact on particle sims?
goldleafYes, the peak level was somewhere around 11.3 - 11.5, so pretty much out of memory, yes.
goldleafIndeed I was already considering having a Linux setup parallel to my Windows (main) system but so far I havn' found a way to conviniently share files between them. I was actually surprised to see what it takes to share files that are on the same hard disc. It's bizarre that with dropbox it's easier to share files between seperate machines than on one and the same machine.
goldleafI can do that too, on about 5 frames
goldleafYes, at least it brings clarity. That means for now my liquid experiments are over and I will focus on stuff my machine can handle.
- Enivob
- 2658 posts
What you really need, above all else, is free disk space. No matter how much memory you have you will eventually have to write either .sim files or .bgeo files to the disk and this is when you will need free space.
You can configure Houdini to not use RAM at all for fluid sims and have it spool directly to the disk. This is one solution to simming on a lower spec machines. This means your sim will run a bit slower (the speed of your disk drive) but you may be able to sim above your computer's typical ability.
OpenCL graphics card acceleration is turned OFF by default so to leverage that you need to enable it in the solver. In my experience it is about a 30% increase in simming speed when enabled.
You can also employ basic tricks to sim lower and render higher. For instance sim with less particles, skin the fluid and then subdivide afterwards. Also you can use displacement materials to make your fluid look more complex than it really is. Also let's not forget our most useful tool, motion blur. After all that fluid is moving so blur the flank out of it.
Having said that, it always comes back to solving for the shot, not just solving for some science experiment to test a system. We can all invent a scene that our computer can not solve. Look at the shot requirements and the camera placement and scale needed and begin there.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- Luke Letellier
- 241 posts
When you guys run out of RAM on a sim, what happens? It seems that for many of you the system starts using the disc - which is strange because even with a 64 GB system, Houdini will crash on my Windows 8 system when it hits the RAM limit.
I've also found that a simulation with a low particle count but a large velocity field takes up a ton more RAM than a high particle count / small velocity field sim.
- goldleaf
- 4259 posts
Graphics card does influence sim speed in a gui session, independent of OpenCL in solvers. After cooking, Houdini has to draw stuff in the viewport. You can see this by running a sim in hbatch vs Houdini, and either timing it yourself by hand or using the Perfromance Monitor.
Also, viewing collision geometry can also slow things down in many cases, though this gets better with each release; still not recommended to always view collision get though, just when debugging/verifying collisions. Obviously your system will determine how much this impacts, but with detailed colliders, I could see a difference even on a Quadro K5000 at a place I used to work.
I'm o.d.d.
