Parent object relative path
   6965   3   1
Hello everybody,
Is there a way to get a relative path to the parent of an object. By parent, I do not mean the parent “network container”. I mean the node connected to Input 0.
For example, inside a CHOP Network, which is inside an SOP, I have an Object node. I want the Reference Object parm to point to the SOP object's parent.
Let's say the parent name is “Null”. The relative path is “../../../Null”. However, I do not want to hardcode “Null”. I would like this to be dynamic.
Is there a way to do this?
Thanks in advance
I think this is what you want?
`opinputpath(“../../..”, 0)`
so let's say your hierarchy is
/obj/GeoObject/chopnet/ObjectCHOP
to get Object connected to first input of GeoObject from ObjectCHOP's targetpath parm you will type:
`opinputpath(“../..”, 0)`
it will simply get first input node of the node 2 levels above the ObjectCHOP, which is first input of GeoObject node
EDIT: too slow
awesome, thanks guys
