I saw this in a tutorial some time ago, and I can't remember how to do it.
I have a structure with many pieces, made with the copy SOP. I want to color each copy randomly, based on a color ramp set to constant interpolation. I want to use a ramp, so I can have some colors appearing more often than others (these colors will have a larger range in the ramp).
Any ideas?
Color each copy differently, according to ramp colors
7905 3 1- alexpi
- 41 posts
- Andy_23
- 918 posts
Since I like to have a little explanation for attached files :-) here we go:
Use an attributerandomize SOP to create an attribute with randomization on your points before copying and set the ‘use template point attribs’ on the copy SOP to propagate the attribute to your copies. After the copy SOP use a color SOP set to ‘ramp from attribute’ with the attribute name from the attributerandomize SOP.
I hope this is what you were looking for.
Andy
Andy
- alexpi
- 41 posts
- cybernetix
- 22 posts
