Hi guys,
Struggling with this one, I am running 13 apprentice without a problem but somehow H14 doesn't want to show the shelves.
This is the error I am getting on the terminal:
Could not initialize the help server:
File “<stdin>”, line 1, in <module>
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\houdinihelp\__init__.py”, line 3, in <module>
import cgi
File “C:\PYTHON26\LIB\cgi.py”, line 40, in <module>
import urllib
File “C:\PYTHON26\LIB\urllib.py”, line 26, in <module>
import socket
File “C:\PYTHON26\LIB\socket.py”, line 46, in <module>
import _socket
ImportError: DLL load failed: The specified module could not be found.
Error finding shelf files:
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\shelfutils.py”, line 13, in <module>
import assetdownload
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\assetdownload.py”, line 5, in <module>
import urllib
import socket
import _socket
import urllib
import socket
import _socket
import urllib
import socket
import _socket
import urllib
import socket
import _socket
import urllib
import socket
import _socket
Error while populating shelf with shelf tool assets.
import urllib
import socket
import _socket
Error while updating shelf with shelf tool assets.
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\sas\localassets.py”, line 9, in <module>
import urllib
import socket
import _socket
Error while checking for updates
import urllib
import socket
import _socket
any ideas on how to solve this?
Thanks,
Cris
Houdini 14, shelves not loading
7172 4 1- cgcris
- 67 posts
- edward
- 7722 posts
It looks like Houdini is loading the python 2.6 distro that you've separately installed on your system. This probably happened to work ok in H13 because it also defaulted to python 2.6. However, H14 now defaults to using python 2.7 and so now you're getting a bunch of conflicts.
Take a look at how Python finds modules here:
https://docs.python.org/2/using/windows.html#finding-modules [docs.python.org]
I'm guessing that one of those items are set on your system globally to always using python 2.6:
- PYTHONPATH environment variable, and/or
- One of the those listed registry keys
- cgcris
- 67 posts
- martinibianko
- 3 posts
- edward
- 7722 posts
