hello,
im trying to get effect point propagate, but i got missing node.
is there any way to get “add Point to group” node inside vopsop at houdini 14?
missing add to point group node at H14
7690 6 0-
- anto187
- 23 posts
- tamte
- 9428 posts
- anto187
- 23 posts
- tamte
- 9428 posts
when using Set Attribute VOP, you need to specifically plug a membership value (0 or 1 ) into Value input, su just plug constant with value 1 in there
then obviously decrease your pcopen radius a bit
to be more precise you may want to use Maximum Merge Mode instead of Add, but it seems that it doesn't matter with groups so never mind
you can as well just use Solver SOP instead of whole dopnet with sop solver setup as a shortcut, but that doesn't matter eighter
- anto187
- 23 posts
verrywell tamte, really thanks for your help in your bussy time.
here's the file that has fixed if maybe someone need it to.
regards
anto187.wordpress.com
ops:
ops:
regards
ops:
ops:
- anoopfx
- 2 posts
- iduffy
- 1 posts
