Another Houdini HQUEUE question please!
19658 27 5-
- Goddy McRoodt
- 35 posts
Hi Guys,
i recently acquired houdini Indie and very happy with it.
Im trying to set up a farm of 4 pc's. All 4 have Windows 8.1 64 on it.
1 workstation (server and client)
3 farm pc's (client)
1 2TB NAS for shared folder (can this work in small farm setup?)
Everything is linked to a 5 port switch.
I put hqserver on my main workstation, and it only see's itself in hqueue web interface, no other clients. the other machines in the Hclient log files read:
“no connection could be made because the target machine actively refused it”
any suggestions? I installed all server and client stuff with default settings so i didn't customize the ports and names
i tried disabling as many firewall / defender / security centre stuff as i could but still no go.
Or should i just install linux on the client machines. I would still like to use windows on my main workstation but i dont mind dropping linux on the farm pc's if it will mean Hqueue will work.
Director at polycat studio
- Cigoler
- 70 posts
- Luke Letellier
- 241 posts
- Goddy McRoodt
- 35 posts
when i put 127.0.0.1 it says the same thing as just leaving it localhost.
“actively refuses it”
when i put network ip “169.254.7.134” it can't find the server and gives error
getaddrinfo failed
it gives this error when i put any random name.
Why am i actively refusing the client pc's, i wish i could speak to my computer
getaddrinfo failed
- Goddy McRoodt
- 35 posts
yaay got it working
i am a huge idiot ofcourse.
i did not set the right stuff in hqserver file.
i set it to right values:
use = egg
aste#http
host = 169.254.7.134
port = 5000
and my client to right values in hqnode
server = 169.254.7.134
port = 5000
it now sees the thing. Next step getting a render out
use = egg
aste#httphost = 169.254.7.134
port = 5000
port = 5000
- Goddy McRoodt
- 35 posts
- Goddy McRoodt
- 35 posts
- Goddy McRoodt
- 35 posts
ok got it “all” working.
only issue i need to fix now is i get an error when i use $JOB but not when i use $HIP. Even if both variables point to the EXACT SAME location. So i am messaging support now to see if they can help me.
the error i get is it cannot save mantra renders when i use $JOB.
“Error: Failed to create file ”Z
/project/blah.jpg : No such file or directory“.”
but when i use $HIP as the variable it can save that location no problem
here is the phenomenon
/project/blah.jpg : No such file or directory“.”but when i use $HIP as the variable it can save that location no problem
- Goddy McRoodt
- 35 posts
that problem is also now fixed. everything works as it should now,
thanks sidefx support
Hello Goddy,
Try setting $JOB to the UNC path version of Z: (i.e. //host_machine_name/share_name).
Windows services, like the HQueue Client service, have network limitations. Mapped network drive letters are not guaranteed to be accessible by services. However UNC paths will work.
And the reason why $HIP works is because HQueue opens the .hip file on the farm using a UNC path so Houdini internally sets $HIP to the UNC path.
Support
- paleoPixels
- 26 posts
- Goddy McRoodt
- 35 posts
Hey Paleo!
That is related to file paths. Make sure everything in your scene navigates through $JOB.
So make sure your pc, and the network render pc navigates through $JOB to the file path, be it your saved scene file, or texture path, anything.
So take this scenario,
you have a file server called “fileserver”
you have “fileserver”'s network drive mounted on YOUR pc as Z:
you have the same network drive mounted on your render pc as Y:
So lets say you saved your scene file on Z
projects/myscene/scene.hip , obviously when your hqueue pc opens the job, it fails fast because it does not see “Z
So the best way to do it is to use network names instead. So instead of using “Z
projects/myscene/scene.hip”, use $JOB/projects/myscene/scene.hip
where $JOB is “\\fileserver”, which is your network pc's location
in houdini, click on the top tab “edit” then “aliases and variables”, click on the “variables” tab, click on “JOB” and insert your file path there. mine looks like this:
now that you have your LOCAL pc set up with this $JOB variable pointing to your file server, you have to do the same at HQUEU.
Go to your HQUEU node and add this variable there as well.
please note, i used 3 backslashes, middle mouse click on the text “variable value” and see what the code evaluates as, houdini has a small bug where the first slash goes away and you end up with 2 which is correct. (two “\\” means network path or domain name path)
now go middle mouse on one of your $JOB paths and see it evaluate correctly like this:
please inbox me if you need some more details or help over skype or something
Cool!
”So the best way to do it is to use network names instead. So instead of using “Z
projects/myscene/scene.hip”, use $JOB/projects/myscene/scene.hipwhere $JOB is “\\fileserver”, which is your network pc's location
Cool!
- Goddy McRoodt
- 35 posts
- paleoPixels
- 26 posts
- paleoPixels
- 26 posts
- Alex Kravtsov
- 21 posts
- Goddy McRoodt
- 35 posts
Hi Alex,
Make sure your server computer also knows where this file, both your workstation and render node need to have access to the same files, in the same way. Firewalls / permissions can also hurt.
I can help with more information like - what operating systems between the nodes, are they looking at the same file server etc.
upload your scene as well then i can have a look
G
G
- Alex Kravtsov
- 21 posts
- Goddy McRoodt
- 35 posts
Hi thanks for the files!
Ok the “cannot find fild” refers to your houdini scene, so the hqeue node cannot find your .HIP file.
i see your scene aliases and variables for $JOB is “//RFServer/hq/projects” but your ENV on the HQUEU node is “\\RFSERVER\HQ\PROJECTS\TEST”
Make these 2 the same, and be sure to navigate through the $JOB part of your save dialog box to have everything $JOB. If you use $HIP the render node might not understand where everything needs to go
G
G
Edited by Goddy McRoodt - Jan. 29, 2018 08:49:14
- Alex Kravtsov
- 21 posts
- Alex Kravtsov
- 21 posts
