I understand Indie has restrictions with external renderers, I was surprised to find Wren was not active, it's internal? I could be getting this wrong by i run a wren render I get the error
command Exit code: 1
Unknown command: Limted_commical_ifd
I was playing around with toon shading and wren is the the method suggested to do the outlines. Does anyone have another suggestion/workaround or is there a chance SESI is going to change this restriction?
Cheers
Karl
Wren & Indie
1945 4 1- LostInTheLight
- 2 posts
- electricalpencil
- 149 posts
I'm with you on this no external renderer restriction, I've been watching the octane plugin development and it really makes me sad that won't be an option since I can't afford a full houdini license.
I think mantra is a wonderful renderer because of its power but it also has a huge learning curve and also no GPU rendering abilities. Being able to use what you are comfortable with could attract a lot of new users.
Frankly I think its a bit short sighted of SESI.
- awong
- 818 posts
- LostInTheLight
- 2 posts
- awong
- 818 posts
