I'm trying to copy a circle on a circle, with Rotate To Normal flag on. But instead of expected result I see something not clear.
H7.0.231 for linux & windows.
Pic:
Scene file:
http://www.cgtalk.ru/~hoknamahn/bugreport/copy_sop.hipnc [cgtalk.ru]
Copy SOP bug or wrong /dev/hands?
3355 4 0- hoknamahn
- 398 posts
- JColdrick
- 4140 posts
- hoknamahn
- 398 posts
- JColdrick
- 4140 posts
Your hip file looks the same here in 7.0.349 when loaded, and when I make the change I'm referring to, all the circles are lined up facing outward along the circle i.e. all facing away from the centre of the main circle, which I would consider to be correct. I'm talking about the circle you're copying, not the big primary circle template. It's initally created orientation is relevant.
I suppose it's possible there was a bug with the version you're running that was corrected. Doesn't ring a bell, though.
J.C.
J.C.
John Coldrick
- EigenAlex
- 639 posts
