Hotkey for Network toggle?
7434 13 0-
- Werner Ziemerink
- 1269 posts
- anon_user_89151269
- 1755 posts
- Werner Ziemerink
- 1269 posts
You know how quick it is to navigate between modeling, animation, Rendering and ICE menus in Softimage using hotkeys.
I think workflow in Houdini can gain a good speedup by having hotkeys to jump from Geo to Shop and to Out Networks. Look at the speed gain by having hotkeys to jump between the different viewports.
I just wanted to know if anybody knows of any hotkeys to do this as I could not find it in the hotkey manager. I will RFE this if I get no answer.
- Doudini
- 333 posts
- Werner Ziemerink
- 1269 posts
- mandrake0
- 655 posts
- Werner Ziemerink
- 1269 posts
- pezetko
- 392 posts
In meantime you can use these Shelf scripts for faster context switching with custom shortcuts.
Please follow install instructions in the archive.
Unfortunately pane under mouse cursor method is not implemented yet so it picks first opened network tab instead the one under cursor.
Hope it's useful.
EDIT: Simplified deployment using Houdini's native paths for custom modules.
Hope it's useful.
- Cameron W
- 31 posts
- aekorps
- 21 posts
pezetko
This is awesome, Petr! Thanks so much for posting this!
I added a MAT switch context to the pz_switch_network_context.shelf file as well. Hope you don't mind, I'm reposting it with that added.
Thanks again, this will be a great speedup.
- shadesoforange
- 203 posts
While you can do this with python, SideFX added this feature not too long ago. I can't post a screenshot because I'm at work, but if you're in the network editor, there's a bar at the top with these entries: “Add”, “Edit”, “Go”, “View”…
In the “Go” dropdown you will find Options like: “Objects”, “Materials” etc. which correspond to the contexts. You can bind these options to hotkeys. You can find these hotkey options in the Hotkey Manager under the context “Houdini - Panes - Network Editor”. They are called the same way as they are in the network editor dropdown.
I hope this helps.
I hope this helps.
Manuel Köster - Senior Technical Artist @Remedy Entertainment
https://www.remedygames.com/ [www.remedygames.com]
http://shadesoforange.de/ [shadesoforange.de]
https://twitter.com/ShadesOfOrange_ [twitter.com]
- xilofoton
- 85 posts
- shadesoforange
- 203 posts
xilofotonshadesoforange… by clicking on them with Shift+Ctrl+Alt
In the “Go” dropdown you will find Options like: “Objects”, “Materials” etc. which correspond to the contexts. You can bind these options to hotkeys…
Wait what?? Can you elaborate?
- Cameron W
- 31 posts
