simple growth effect, a film roll
   7573   7   0
hello
There are several growth topics and files, but I'm new to Houdini and most of them uses the advanced setup that I don't understand.
- I want a single film strip to grow from nothing to full length.
http://iyfilm.org/2013/10/18/welcome-to-iyfilm-org/ [iyfilm.org]
with textures ..
- here, I think is a simpler one :
Houdini Crystal Growth
https://vimeo.com/16289316 [vimeo.com]
It would be great if someone points me to the right direction and give me a simple file that does what this demo does.
thank you very much for your time.
just made very simple setup.
it's not the same like that in the video they used particles.
please take your time to learn with the tutorials.
simple_growth_effect_092015.hipnc (50.2 KB)
cool , thank you.
I'm trying my best to catch up with the latest tutorials.
This setup as you said is very basic and I'm aware of it.
I just needed it to be particles like the demo.
and please help me out with my first question. I have a project that I need the answer how to do it in Houdini!!
edit :do I have to use simple clip sop to clip my geometry instead of growing?
or is there any better way?
film rell.hip (394.8 KB)
hmm i think you have to make your setup a bit different.
i think your control would be a curve for controlling the shape of the filmroll.
so you have to start with a curve and the you can build up each frame. like that you get more control.
look the buildings tutorial they should help you:
https://www.sidefx.com/index.php?option=com_content&task=blogcategory&id=222&Itemid=383 [sidefx.com]
btw. made something with particle have fun to play…
when i have got some time i can make a solution.
particle_trail_092015.hipnc (255.6 KB)
thank you..
the file has already helped me to move on…
I'll be waiting for more help.
made some tests i'm not happy with it but maybe you find something useful OR MAYBE NOT. :-)
filmroll_test_02.hipnc (492.8 KB)
Hi Hadi
Maybe my test would help you if you add a deformer at the end of nodes to deform the whole roll and use grow parameter on the animate node to reach your desired look. But fixing the length of the 3 end copys of the main shape is a bit tricky and maybe someone could help you on that.
film.hipnc (61.8 KB)
Philomath
Mandrake! and Mostafa!
thank you very much
definitely helping me out… really appreciated!
I'll test them and .. may be next questions right? :wink:
