I am returning to compiling my Houdini code on the Windows platform.
Have people been able to use VS2012 x64 Express to build Houdini plugins/SOP/standalone application ?
Seems that hcustom is looking for the cl.exe in some amd64 directory which is not present (at least in the VS2012 Express I installed)
Working around that, there was some link issues with _BitForward*64 missing
I have been able to build 64 bit plugins and apps for other DCC so I believe my setup is fine (but you never know)
Any wisdom I can tap into ?
Cheers
H15 : Visual Studio 2012 / VC11 Express - some issues
2012 1 0- nicholas_yue
- 301 posts
- edward
- 7721 posts
hcustom and the Makefiles in the HDK assume you're compiling using the native 64-bit compiler, which is not included with VS2012 Express. VS2012 Express does include the 64-bit cross- compiler though so you should be able in theory use that. However, you'll need to alter the paths in the Makefiles yourself.
