Houdini 15 Rendering Segmentation Fault
5262 5 1-
- Aidan Ryan
- 12 posts
Hello all, I have been trying to render a project for some time now, and have made the project three separate times and attempted to render it on both the production build of H15 and .305 to try to get it to work. I get error 139 (doesn't mean anything significant). After tinkering for the last day, I got an error to read that it was a segmentation fault. The error only shows up on a physically based render, as the other render engines freeze on the first frame. I am attaching my .hipnc file for you all to see. I had no issues like this on H14, and suppose I can roll back to 14 to get it to render.
- Werner Ziemerink
- 1269 posts
- edward
- 8111 posts
- moferad
- 19 posts
Aidan, I currently found out this has only been an issue on the linux version of houdini, if you're able to work on the Windows version it should be fine, that being said , I tried different nvidia drivers on mint linux with little to no change.
my only solution was to render on a windows machine (at the moment).
- Werner Ziemerink
- 1269 posts
- Aidan Ryan
- 12 posts
