How remove smooth from break geometry?
1561
3
0
- LuSkar
- 28 posts
If i use a Break node i have that result in render, but i need the same result as Voronoi. How fix that?
- Andy_23
- 918 posts
Hi there,
add a Normal SOP after your Break SOP and adjust to your liking.
- LuSkar
- 28 posts
Andy58
Hi there,
Hello, this gives a different result - you can see some artifacts on the geometry.
- Andy_23
- 918 posts
Ok, try adding the normal SOP before the break SOP, then the result looks as smooth as the unbroken sphere.
