Metaballs/Copy SOP - Jagged mesh
2529 4 3- eddgarpv
- 64 posts
I'm adding metaballs to resampled curve points (using copy sop) and I'm getting some jagged meshes when rendering. I tried adding more points to the curve, converting to vdb and smoothing there, but even using very small voxel size, I can't seem to get rid of it.
Any hint on what could be causing this?
thanks!
thanks!
- neil_math_comp
- 1743 posts
If you don't absolutely need it to be metaballs, you could use PolyWire on the curve.
- eddgarpv
- 64 posts
- galagast
- 252 posts
- eddgarpv
- 64 posts
