using a pre-render script and generators yields scope errors.
blacklist =
element = “lol”
if not any(name in element for name in blacklist):
print “not in list”
I am putting this script as a “pre-render script” but it doesn't like the “any” generator function. Is this known?
Houdini Generator Expression fail
1306 1 0- schiho
- 101 posts
- Enivob
- 2540 posts
Where are you defining the function any?
it does not exist, right?
Just write the code in it's long format till you get it working then try to condense it down into a single line.
Even though you only have a single line, you can paste multiple lines of code into that field. I have put over 100 lines of code into a Post-Write field for a ROP Driver.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
