Hey,
Is anyone else experiencing issues with launching houdini from a terminal on OSX?
If I load houdini from the Houdini.app using the GUI it loads absolutely fine, however if I launch the houdiniTerminal.app and then try and run
houdini
It crashes every time with the same stack trace at the very bottom.
Anyone else having the same issue, or know how to resolve this?
Cheers
Adam
Process: houdinifx
Path: /Applications/Houdini 15.0.455/Houdini FX.app/Contents/MacOS/houdinifx
Identifier: houdinifx
Version: 15.0.455 (15.0.455)
Code Type: X86-64 (Native)
Parent Process: ???
Responsible: Terminal
User ID: 501
Date/Time: 2016-05-01 19:45:53.841 +0100
OS Version: Mac OS X 10.11.4 (15E65)
Report Version: 11
Anonymous UUID: C778AB75-F8FE-ADB1-D8D3-782137CCBBA4
Sleep/Wake UUID: D3AF8952-2272-4763-8C6A-2B9E20CEB1D2
Time Awake Since Boot: 210000 seconds
Time Since Wake: 720 seconds
System Integrity Protection: disabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0xffffffffffffffe8
VM Regions Near 0xffffffffffffffe8:
–> shared memory 00007fffffe18000-00007fffffe19000 r-x/r-x SM=SHM
Application Specific Information:
/Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libHoudiniAPPS3.dylib
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libstdc++.6.dylib 0x00007fff84408799 std::string::assign(char const*, unsigned long) + 41
1 libPtex.dylib 0x0000000110cc1af8 0x110cba000 + 31480
2 libPtex.dylib 0x0000000110cbe7c3 0x110cba000 + 18371
3 libHoudiniUT.dylib 0x000000010f218a11 HPTEX_Cache::stat(char const*, int&, int&) + 65
4 libHoudiniUT.dylib 0x000000010f537217 til_Map::checkFileType() + 199
5 libHoudiniUT.dylib 0x000000010f53a32c TIL_TextureMap::setMap(char const*, char const*, TIL_Raster*, bool) + 140
6 libHoudiniUT.dylib 0x000000010f53a46d TIL_TextureMap::TIL_TextureMap(char const*, char const*, TIL_Raster*) + 173
7 libHoudiniAPPS3.dylib 0x0000000103ba78b4 _GLOBAL__sub_I_IM_ViewerManager.C + 116
8 dyld 0x00007fff646aefeb ImageLoaderMachO::doModInitFunctions(ImageLoader::LinkContext const&) + 265
9 dyld 0x00007fff646af164 ImageLoaderMachO::doInitialization(ImageLoader::LinkContext const&) + 40
10 dyld 0x00007fff646ab79d ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 305
11 dyld 0x00007fff646ab732 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 198
12 dyld 0x00007fff646ab732 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 198
13 dyld 0x00007fff646ab623 ImageLoader::processInitializers(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 127
14 dyld 0x00007fff646ab893 ImageLoader::runInitializers(ImageLoader::LinkContext const&, ImageLoader::InitializerTimingList&) + 75
15 dyld 0x00007fff6469e0f1 dyld::initializeMainExecutable() + 208
16 dyld 0x00007fff646a1e5d dyld::_main(macho_header const*, unsigned long, int, char const**, char const**, char const**, unsigned long*) + 3793
17 dyld 0x00007fff6469d276 dyldbootstrap::start(macho_header const*, int, char const**, long, macho_header const*, unsigned long*) + 512
18 dyld 0x00007fff6469d036 _dyld_start + 54
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x3ffffffffffffffa rbx: 0x0000000000000013 rcx: 0x0000000000000008 rdx: 0x0000000000000013
rdi: 0x0000000000000000 rsi: 0x00007fc23a52b3c8 rbp: 0x00007fff5c3ee910 rsp: 0x00007fff5c3ee8f0
r8: 0x0000000000000002 r9: 0x0000000000000000 r10: 0x000000011211de18 r11: 0xffffffffffffd4e1
r12: 0x00007fc23a5373c0 r13: 0x00007fc23a5374b8 r14: 0x00007fff5c3eec60 r15: 0x00007fc23a52b3c8
rip: 0x00007fff84408799 rfl: 0x0000000000010293 cr2: 0xffffffffffffffe8
Logical CPU: 2
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x10380c000 - 0x10380cfff +com.sidefx.HoudiniFX (15.0.455 - 15.0.455) <A9D29BAC-281D-3120-9F74-0DFDDE5EBAE7> /Applications/Houdini 15.0.455/Houdini FX.app/Contents/MacOS/houdinifx
0x103810000 - 0x103811fff +com.sidefx.houdini (15.0 - 15.0.455) <CF55151A-BF3A-356B-AAF7-E40E4FB81A47> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Houdini
0x103815000 - 0x103f55fff +libHoudiniAPPS3.dylib (0) <8CCCA271-E1AE-3D32-9FBD-66BE662159F0> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libHoudiniAPPS3.dylib
0x1043e6000 - 0x104784fff +libHoudiniRAY.dylib (0) <C20BED08-4DD3-3F99-82B2-4514E58FD455> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libHoudiniRAY.dylib
0x10495e000 - 0x10497bff7 +libaudiere-1.9.4.dylib (0) <68B65B75-AF4F-3A6E-9876-CA0DFFC06920> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libaudiere-1.9.4.dylib
0x1049ad000 - 0x1049fbfff +libsndfile.1.0.17.dylib (0) <F022AE34-9BE1-3E34-BBA0-65DD998F0A16> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libsndfile.1.0.17.dylib
0x104a18000 - 0x104f0eff7 +libHoudiniAPPS2.dylib (0) <E230CE24-4FFF-3368-B892-D7425CEB6480> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libHoudiniAPPS2.dylib
0x10524b000 - 0x1056bffff +libHoudiniOPZ.dylib (0) <E21C8C77-014E-3BEF-8803-C5BAA6AEC827> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libHoudiniOPZ.dylib
0x105a26000 - 0x10632bff7 +libHoudiniOP3.dylib (0) <EA462726-D9EA-3121-AB0D-0549FE9D82AB> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libHoudiniOP3.dylib
0x10676d000 - 0x106784ff7 +libcollada_dae.dylib (0) <B3DC12CF-6CBA-310B-8588-974A6B06C340> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libcollada_dae.dylib
0x106799000 - 0x106938ff7 +libcollada_dom.dylib (0) <C65FB08E-4C5B-3CBB-9576-1C4A1D875126> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libcollada_dom.dylib
0x106a5e000 - 0x106a62fff +libcollada_LIBXMLPlugin.dylib (0) <434FE4E9-1B35-3072-B00B-701C3596A9D9> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libcollada_LIBXMLPlugin.dylib
0x106a68000 - 0x106a69fff +libcollada_stdErrPlugin.dylib (0) <37B8A10D-FAEB-3237-A7FE-379B8CCA9CE3> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libcollada_stdErrPlugin.dylib
0x106a71000 - 0x106a76ff7 +libcollada_STLDatabase.dylib (0) <78CD8A51-7D13-3908-8C3E-FA5846799A4B> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libcollada_STLDatabase.dylib
0x106a80000 - 0x106adaff7 +libHoudiniAPPS1.dylib (0) <232DC7A3-EF5B-3B68-93CF-491765CF32C7> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libHoudiniAPPS1.dylib
0x106b10000 - 0x106b13fff +libHoudiniDEVICE.dylib (0) <D4901EC5-50B7-34C7-95AC-0257A69A4BB5> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libHoudiniDEVICE.dylib
0x106b1d000 - 0x106f72ff7 +libHoudiniUI.dylib (0) <C2740DB0-3DC4-3D0D-B80A-CAF17EC7A066> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libHoudiniUI.dylib
0x1071f6000 - 0x107becfff +libHoudiniOP2.dylib (0) <431C60E4-30B0-33B7-BBF9-7EBF39BBA1DE> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libHoudiniOP2.dylib
0x108293000 - 0x108804ff7 +libHoudiniOP1.dylib (0) <8D701BAF-E91A-3EDC-8353-8C68C121E493> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libHoudiniOP1.dylib
0x108c6e000 - 0x108d40ff7 +libQtOpenGL.4.8.5.dylib (0) <3E2B2FF1-3724-35F4-B153-B7BB4E8EBF18> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libQtOpenGL.4.8.5.dylib
0x108d87000 - 0x108dd1ff7 +libQtSvg.4.8.5.dylib (0) <9F1222F6-9815-3CB5-BD7E-02918C4C6BD4> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libQtSvg.4.8.5.dylib
0x108df2000 - 0x109786ff7 +libQtGui.4.8.5.dylib (0) <3BAB4599-6C7F-36D3-8B89-B6B51256122D> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libQtGui.4.8.5.dylib
0x109a36000 - 0x109a68ff7 +libpng12.0.dylib (0) <20E25910-9BA9-3DD4-AE10-6AEB9CC98F83> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libpng12.0.dylib
0x109a75000 - 0x10b069ff7 +libQtWebKit.4.9.4.dylib (0) <9F88EA20-C90B-33EA-9C41-3C382CD4FD50> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libQtWebKit.4.9.4.dylib
0x10b8ba000 - 0x10b9e0ff7 +libQtNetwork.4.8.5.dylib (0) <916F6913-F799-3708-8E02-0AA9D41BD054> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libQtNetwork.4.8.5.dylib
0x10ba48000 - 0x10bcfeff7 +libQtCore.4.8.5.dylib (0) <9ED39739-FDFB-350C-933B-A71DEFF8FDD3> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libQtCore.4.8.5.dylib
0x10bda9000 - 0x10c606ff7 +libHoudiniSIM.dylib (0) <664718E7-6788-331C-9D58-6F6C501C877A> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libHoudiniSIM.dylib
0x10cab1000 - 0x10e176ff7 +libHoudiniGEO.dylib (0) <6438DC05-ED77-3815-A63D-A16A33582D4A> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libHoudiniGEO.dylib
0x10eb53000 - 0x10ef60ff7 +libHoudiniPRM.dylib (0) <F9C2AB4D-5F89-312D-86A8-FE47571FFD77> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libHoudiniPRM.dylib
0x10f130000 - 0x1104e6f37 +libHoudiniUT.dylib (0) <2D779AC1-57B3-3A3B-8164-0CD5DCA7561D> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libHoudiniUT.dylib
0x110b65000 - 0x110be8ff7 +libfreetype.6.dylib (0) <96D549EF-CB6D-3194-BF23-A6CBA810EE11> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libfreetype.6.dylib
0x110c18000 - 0x110c6ffff +libtiff.4.dylib (0) <FB99D92B-EBE4-3516-A4A3-DDB1396BA752> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libtiff.4.dylib
0x110c8d000 - 0x110cadff7 +libjpeg.62.0.0.dylib (0) <8E5CFB20-551D-3EB6-AC61-7AE38A028128> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libjpeg.62.0.0.dylib
0x110cba000 - 0x110cf3fff +libPtex.dylib (0) <645ECE9F-8C17-3FF7-AA3D-AEACFA6A7F88> /Applications/Autodesk/*/Maya.app/Contents/MacOS/libPtex.dylib
0x110d4a000 - 0x110eb4fcf +libcurl.4.dylib (0) <44DC7938-02F9-3A8F-AF94-AF6C64BBAEBA> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libcurl.4.dylib
0x110f33000 - 0x110f75fff +libssl.1.0.0.dylib (0) <86C40263-9074-35AD-B80C-E6AF3696F2EB> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libssl.1.0.0.dylib
0x110f94000 - 0x1110b2fcf +libcrypto.1.0.0.dylib (0) <AC322884-2352-369C-AADD-02B8EEC777C4> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libcrypto.1.0.0.dylib
0x111125000 - 0x111252ff7 +libxml2.2.dylib (0) <749876C2-0FFC-3178-B43E-5930C5E8DA63> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libxml2.2.dylib
0x1112ba000 - 0x111397fff +libiconv.2.dylib (0) <9F61FBD8-AADE-33B2-88FC-D68EE97C1089> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libiconv.2.dylib
0x1113b4000 - 0x111448fff +libboost_regex-clang-darwin61-mt-1_55.dylib (0) <9DC12FD4-CDEB-3006-B95F-937AC9A634BF> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libboost_regex-clang-darwin61-mt-1_55.dylib
0x111494000 - 0x1114a3fff +libblosc.dylib (0) <51E6A08B-A6CE-300C-B717-5424B5A40AC2> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libblosc.dylib
0x1114a9000 - 0x111633ff7 +libopenvdb_sesi.dylib (0) <FEE247C7-2CC4-3868-A278-C2E032272E60> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libopenvdb_sesi.dylib
0x1116fb000 - 0x111706fff +libboost_iostreams-clang-darwin61-mt-1_55.dylib (0) <F2836810-97D0-31F9-A7DA-63BFBE1A1EDF> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libboost_iostreams-clang-darwin61-mt-1_55.dylib
0x11171b000 - 0x111727ff7 +libboost_thread-clang-darwin61-mt-1_55.dylib (0) <E9B76624-44FD-34D8-89F4-431B93E76E2C> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libboost_thread-clang-darwin61-mt-1_55.dylib
0x111739000 - 0x11173afff +libboost_chrono-clang-darwin61-mt-1_55.dylib (0) <0E7111AC-1480-32DC-B907-4C24E228DDC0> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libboost_chrono-clang-darwin61-mt-1_55.dylib
0x11173e000 - 0x11173ffff +libboost_system-clang-darwin61-mt-1_55.dylib (0) <88571A89-21F8-361D-B02D-4A0765AA2274> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libboost_system-clang-darwin61-mt-1_55.dylib
0x111748000 - 0x111782fff +libboost_program_options-clang-darwin61-mt-1_55.dylib (0) <126AFB6D-2371-3EA2-BAE3-48C453AE3616> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libboost_program_options-clang-darwin61-mt-1_55.dylib
0x1117ba000 - 0x1117dfff7 +libosdGPU.2.5.1.dylib (0) <01728CEC-FC83-38F0-BF65-9C8A48D6008E> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libosdGPU.2.5.1.dylib
0x1117ef000 - 0x111817fff +libosdCPU.2.5.1.dylib (0) <EE9E94CE-D523-3C1A-91FB-9D34B85C99ED> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libosdCPU.2.5.1.dylib
0x111832000 - 0x111864ff7 +libtbb.dylib (0) <B9EB5E03-AE4B-35B3-87A8-03542DEF818C> /Applications/Autodesk/*/Maya.app/Contents/MacOS/libtbb.dylib
0x11189c000 - 0x1118c3fe7 +libtbbmalloc.dylib (0) <6AAF3988-7E41-3D23-800F-1A36DF2F20F4> /Applications/Autodesk/*/Maya.app/Contents/MacOS/libtbbmalloc.dylib
0x1118f6000 - 0x11190efff +libAlembicAbc.dylib (0) <8AA70803-2DC1-3F87-8A46-014E2F43B0DA> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libAlembicAbc.dylib
0x111922000 - 0x11192aff7 +libAlembicAbcCollection.dylib (0) <2C5D039A-038B-3C33-A73A-0B02C096964F> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libAlembicAbcCollection.dylib
0x111936000 - 0x1119e2fff +libAlembicAbcGeom.dylib (0) <A1C02327-6AAF-3071-AA83-2D5503F5FB6B> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libAlembicAbcGeom.dylib
0x111a15000 - 0x111a39fff +libAlembicAbcMaterial.dylib (0) <3B26FC4B-80E1-321E-B532-5AAF72E51F30> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libAlembicAbcMaterial.dylib
0x111a4e000 - 0x111a5bff7 +libImath.12.0.0.dylib (0) <4E1B57D9-672F-317A-AAED-FFD76DD8784C> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libImath.12.0.0.dylib
0x111a65000 - 0x111a66ff7 +libAlembicAbcCoreFactory.dylib (0) <13E19076-1CBE-3671-95A0-3210C3791293> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libAlembicAbcCoreFactory.dylib
0x111a6a000 - 0x111adeff7 +libAlembicAbcCoreHDF5.dylib (0) <19658E1F-B3C7-32B6-9E23-AA4BDED7E61F> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libAlembicAbcCoreHDF5.dylib
0x111b0d000 - 0x111b1eff7 +libAlembicAbcCoreAbstract.dylib (0) <CABF1DA0-2138-3B83-946E-D9E5847A094C> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libAlembicAbcCoreAbstract.dylib
0x111b3c000 - 0x111b59ff7 +libhdf5_hl.8.dylib (0) <367CC531-8F2B-351D-98BA-18DB665AC47E> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libhdf5_hl.8.dylib
0x111b76000 - 0x111f73ff7 +libhdf5.8.dylib (0) <D1D784F6-8978-3772-8138-CC7C61C59AED> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libhdf5.8.dylib
0x111fb2000 - 0x111fc5ff7 +libz.1.2.7.dylib (0) <0FDDB8E4-1C12-3BD2-B32F-5C7D1CB7DB23> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libz.1.2.7.dylib
0x111fca000 - 0x11200afff +libAlembicAbcCoreOgawa.dylib (0) <426FD345-3073-3944-87E4-5AA6F26CF537> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libAlembicAbcCoreOgawa.dylib
0x112031000 - 0x112039ff7 +libAlembicOgawa.dylib (0) <F0F06264-87FE-3F99-A94B-F4C3AC179155> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libAlembicOgawa.dylib
0x11204a000 - 0x11204fff7 +libAlembicUtil.dylib (0) <BFD9F1C5-77D7-3FDD-9DC6-88B824A33916> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libAlembicUtil.dylib
0x112056000 - 0x112097ff7 +libHalf.12.0.0.dylib (0) <B058B579-4201-3050-8894-97206CEB69D6> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libHalf.12.0.0.dylib
0x11209e000 - 0x1120a4fff +libIex.12.0.0.dylib (0) <A98FDA24-D7A2-3360-9216-E183DC077B76> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libIex.12.0.0.dylib
0x1120b2000 - 0x1120b6fff com.apple.agl (3.3.1 - AGL-3.3.1) <9F89C357-50A4-3978-93AB-D2E68CCFA834> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x1120be000 - 0x1120ebfff +libcilkrts.5.dylib (0) <70F67F64-5BAA-328D-A9C0-A4833913A4F1> /Applications/Autodesk/*/Maya.app/Contents/MacOS/libcilkrts.5.dylib
0x112108000 - 0x112117fff +libblosc.1.dylib (0) <51E6A08B-A6CE-300C-B717-5424B5A40AC2> /Library/Frameworks/Houdini.framework/Versions/15.0.455/Libraries/libblosc.1.dylib
0x7fff6469c000 - 0x7fff646d30d7 dyld (360.21) <D9B236BC-4AC1-325F-B3EF-3F06DBDA7119> /usr/lib/dyld
0x7fff82fa1000 - 0x7fff82fd0ffb libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
0x7fff82fd1000 - 0x7fff82fd1fff com.apple.CoreServices (728.9 - 728.9) <78CB3EAC-A66E-3FD9-A1DF-A9CF227ED3C3> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff8300a000 - 0x7fff8300cff7 libRadiance.dylib (1444) <A5EFA292-AFD4-3FCE-8802-958AD60F75DA> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff83092000 - 0x7fff83096fff com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff83127000 - 0x7fff83137fff libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
0x7fff83138000 - 0x7fff831affeb libcorecrypto.dylib (335.40.8) <9D300121-CAF8-3894-8774-DF38FA65F238> /usr/lib/system/libcorecrypto.dylib
0x7fff83245000 - 0x7fff83250fff libkxld.dylib (3248.40.184) <6F776D34-D06C-3C48-B753-D0FB375A4A8A> /usr/lib/system/libkxld.dylib
0x7fff83264000 - 0x7fff8328fffb libarchive.2.dylib (33.20.2) <6C370A21-63FD-3A68-B4B3-5333F24B770B> /usr/lib/libarchive.2.dylib
0x7fff83290000 - 0x7fff832a5fff com.apple.AppContainer (4.0 - 261.40.2) <F220E702-1C00-3BD2-9943-C7E75C3B4418> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff832b8000 - 0x7fff832b8fff com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff832c5000 - 0x7fff832e1ff3 libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
0x7fff8348d000 - 0x7fff83493fff com.apple.XPCService (2.0 - 1) <5E2122D6-FFA2-3552-BF16-9FD3F36B40DB> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fff83494000 - 0x7fff834e0ffb com.apple.HIServices (1.22 - 549) <E4E1BD10-F475-3E19-9E0B-A5071D158F47> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff834e1000 - 0x7fff83605fff libsqlite3.dylib (216.4) <280D67B8-F93D-3587-A146-19F36C817548> /usr/lib/libsqlite3.dylib
0x7fff83627000 - 0x7fff83627fff com.apple.Accelerate (1.10 - Accelerate 1.10) <185EC96A-5AF0-3620-A4ED-4D3654D25B39> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff836b2000 - 0x7fff837a2fff libJP2.dylib (1444) <27371567-A122-3217-ADA0-3A446EF6A3E9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff837c3000 - 0x7fff837cefff com.apple.AppSandbox (4.0 - 261.40.2) <52766210-B6EB-3B73-AB1B-42E0A9AD2EE8> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff837d7000 - 0x7fff83811fff com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff83812000 - 0x7fff83901ffb libxml2.2.dylib (29.5) <4096C2EA-6659-3F22-AC60-1E2F30BDD2B7> /usr/lib/libxml2.2.dylib
0x7fff83988000 - 0x7fff8398dfff com.apple.TCC (1.0 - 1) <50F7EC60-5B21-3B9B-BF2F-F037EA7B12FB> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff83994000 - 0x7fff8399afff com.apple.IOAccelerator (205.3 - 205.3) <851B6BF8-5B7F-3FB5-9E45-10AAE3BF7438> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff8399b000 - 0x7fff839e0ff3 libFontRegistry.dylib (155.1) <F3355C6E-ED33-3506-B10E-2F6995D34BC1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff839e1000 - 0x7fff83cd6fff com.apple.HIToolbox (2.1.1 - 807.2) <871E5223-5D03-3649-98AF-9CCA3B41E307> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff83ebc000 - 0x7fff83eedfff com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff83ef3000 - 0x7fff83efeff7 libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
0x7fff83eff000 - 0x7fff83f18fff com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff83f4e000 - 0x7fff83f51ff7 com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff83f7b000 - 0x7fff83fc1ff7 libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
0x7fff84233000 - 0x7fff843d9ff7 com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <082319FC-59F2-3D36-AC9B-94759724E302> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff843da000 - 0x7fff84428ff7 libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
0x7fff84443000 - 0x7fff844eafff com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff844eb000 - 0x7fff84514ff7 libxpc.dylib (765.40.36) <2CC7CF36-66D4-301B-A6D8-EBAE7405B008> /usr/lib/system/libxpc.dylib
0x7fff84515000 - 0x7fff8453efff libsystem_info.dylib (477.40.5) <6B01C09E-A3E5-3C71-B370-D0CABD11A436> /usr/lib/system/libsystem_info.dylib
0x7fff84555000 - 0x7fff845aafff com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff846ae000 - 0x7fff84715fff com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff84716000 - 0x7fff84718fff com.apple.xpc.ServiceManagement (1.0 - 1) <F3E14561-5DF4-3429-98ED-8F27A87A343A> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff84719000 - 0x7fff8471afff libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
0x7fff84726000 - 0x7fff8479bfff com.apple.framework.IOKit (2.0.2 - 1179.40.20) <FB2AD43B-905D-3BD0-BE17-ACE7D4D13E24> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff847de000 - 0x7fff847e1ffb libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
0x7fff847e2000 - 0x7fff847edfff libGL.dylib (12.0.40.6) <4FC6D3F9-6582-3E7D-A7D1-E035F0E26697> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff84d07000 - 0x7fff84d1dff7 libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff84d1e000 - 0x7fff84d89ff7 com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff84e1a000 - 0x7fff84e3cfff com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff84eed000 - 0x7fff850f8fff libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
0x7fff85174000 - 0x7fff8517cffb libsystem_dnssd.dylib (625.40.20) <86A05653-DCA0-3345-B29F-F320029AA05E> /usr/lib/system/libsystem_dnssd.dylib
0x7fff8517d000 - 0x7fff852c2fff com.apple.QTKit (7.7.3 - 2943.3) <88AA19A7-7170-3798-8CBA-B1B8D4763ADB> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff85355000 - 0x7fff85374ff7 com.apple.framework.Apple80211 (11.0 - 1121.34) <AE7795B8-4590-3714-999D-3FBFF6BF5D93> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff85375000 - 0x7fff8537aff7 libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
0x7fff8537b000 - 0x7fff85410fff com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff857a3000 - 0x7fff85a2aff7 com.apple.CFNetwork (760.4.2 - 760.4.2) <24C4A390-3079-358A-8D51-75A3E818A6DF> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff85b74000 - 0x7fff85c99ff7 com.apple.LaunchServices (728.8 - 728.8) <FDA38B17-82E2-322F-A008-B9207A6EA668> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff85c9a000 - 0x7fff85f7fffb com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff85f80000 - 0x7fff85f88fff libGFXShared.dylib (12.0.40.6) <1CDE5AEF-3E44-3547-879E-BB490EE7702C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff85f89000 - 0x7fff85f94fff com.apple.CrashReporterSupport (10.11 - 717) <474544AD-1199-3ECC-90E5-071847BA72C6> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff85f95000 - 0x7fff86391fff libLAPACK.dylib (1162.2) <987E42B0-5108-3065-87F0-9DF7616A8A06> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff864a0000 - 0x7fff864d4ff7 com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff864d9000 - 0x7fff864daffb libSystem.B.dylib (1226.10.1) <CD307E99-FC5C-3575-BCCE-0C861AA63124> /usr/lib/libSystem.B.dylib
0x7fff8657e000 - 0x7fff86580ff7 com.apple.securityhi (9.0 - 55006) <A4CEFD45-C51C-381C-A57B-FF75D90C680F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff865b3000 - 0x7fff865b8fff com.apple.MediaAccessibility (1.0 - 79) <C5E61B45-1967-3602-A48C-31E132B998B2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff865b9000 - 0x7fff866b5ff7 libFontParser.dylib (158.5) <62796E99-36B7-36B6-8D33-5349F88014C3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff8675d000 - 0x7fff868c4fff libBLAS.dylib (1162.2) <A1398FE0-39D2-33EA-9A0F-B2644EEA29A0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff868db000 - 0x7fff868e0ff7 libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
0x7fff868e1000 - 0x7fff86b7bfff com.apple.security (7.0 - 57337.40.85) <7C5B8DEF-3D02-3410-9BD3-2B1251F84D4B> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff86e1a000 - 0x7fff86e3cff7 com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff8709f000 - 0x7fff8710dff7 com.apple.ApplicationServices.ATS (377 - 394.3) <847DBFBA-8D6B-367B-99FD-C6CAA8C05C65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff8715d000 - 0x7fff871b9fff libTIFF.dylib (1444) <2A22E6B7-213B-3253-838F-C3EC3C8F2727> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff871ba000 - 0x7fff871c2fff libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
0x7fff871c3000 - 0x7fff872d2fe7 libvDSP.dylib (563.5) <9AB6CA3C-4F0E-35E6-9184-9DF86E7C3DAD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff87321000 - 0x7fff87329fff libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
0x7fff8732a000 - 0x7fff87387fff com.apple.CoreServices.OSServices (728.8 - 728.8) <4CE49D8A-8304-3347-9379-6075CB906419> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff873c0000 - 0x7fff873c0fff libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
0x7fff879bc000 - 0x7fff879cffff com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff879d0000 - 0x7fff879fdfff libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
0x7fff87a15000 - 0x7fff87a3eff7 libxslt.1.dylib (14.1) <27DE3F2E-CE96-3327-A563-788EE3E2775B> /usr/lib/libxslt.1.dylib
0x7fff87e6a000 - 0x7fff8808bff7 com.apple.CoreImage (11.4.0 - 366.4.19) <6EE4A686-50C8-3D77-A036-BE8AA0F8A2FD> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff880bd000 - 0x7fff880beff3 com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff880bf000 - 0x7fff8810bfff com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff8810c000 - 0x7fff8810ffff libsystem_sandbox.dylib (460.40.33) <30671DCC-265F-325A-B33D-11CD336B3DA3> /usr/lib/system/libsystem_sandbox.dylib
0x7fff88110000 - 0x7fff881c0fff com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff881c1000 - 0x7fff881d8ff7 libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
0x7fff8820a000 - 0x7fff88292fff com.apple.CoreSymbolication (3.1 - 58048.1) <4730422E-4178-34F9-8550-BB92F2A4F44B> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff88293000 - 0x7fff886c1fff com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff88f3f000 - 0x7fff88f90ff7 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <3D62A9B3-67A8-3F8A-A102-05E310249075> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff88f91000 - 0x7fff8909fff3 com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff898a9000 - 0x7fff898acffb libdyld.dylib (360.21) <8390E026-F7DE-3C32-9486-3DFF6BD131B0> /usr/lib/system/libdyld.dylib
0x7fff89b26000 - 0x7fff89b3dff7 libsystem_asl.dylib (323.40.3) <007F9094-317A-33EA-AF62-BAEAAB48C0F7> /usr/lib/system/libsystem_asl.dylib
0x7fff89b41000 - 0x7fff89b41fff libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
0x7fff89b42000 - 0x7fff89b84ff7 com.apple.Metal (56.6 - 56.6) <7DCBE573-B713-3C50-A16E-2F33A84C3CFB> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff89b85000 - 0x7fff89bf4fff com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff89bfa000 - 0x7fff89bfafff com.apple.audio.units.AudioUnit (1.13 - 1.13) <93C1D642-37D4-3692-AD35-DCAD04F9610B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff89bfb000 - 0x7fff89c0cfff libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
0x7fff89c0d000 - 0x7fff89c1eff7 libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
0x7fff8ad0e000 - 0x7fff8ad1cfff com.apple.opengl (12.0.40 - 12.0.40) <AEA28993-BA3E-3E0F-A2F5-88C312ABB634> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff8ad3c000 - 0x7fff8adc5ff7 com.apple.PerformanceAnalysis (1.0 - 1) <608E8C50-6F59-3FEB-B822-D9B02F328716> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff8adc6000 - 0x7fff8adf6ff3 com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <4AAFB1C4-3708-30F9-ACFA-90564347204C> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff8ae2c000 - 0x7fff8ae2ffff libspindump.dylib (197.1) <48F4C673-9F0C-38BE-B550-88241E812518> /usr/lib/libspindump.dylib
0x7fff8aef4000 - 0x7fff8aef6fff com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff8c29c000 - 0x7fff8c2a0fff libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
0x7fff8c2a1000 - 0x7fff8c2acff7 libcommonCrypto.dylib (60075.40.2) <B9D08EB8-FB35-3F7B-8A1C-6FCE3F07B7E7> /usr/lib/system/libcommonCrypto.dylib
0x7fff8c2df000 - 0x7fff8c2ebff7 com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff8c364000 - 0x7fff8c571fff libicucore.A.dylib (551.51) <35315A29-E21C-3CC5-8BD6-E07A3AE8FC0D> /usr/lib/libicucore.A.dylib
0x7fff8c605000 - 0x7fff8c663fff com.apple.SystemConfiguration (1.14 - 1.14) <10082F58-6190-3A7C-8B6C-C12B16DC793A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff8c6b5000 - 0x7fff8c700ff7 com.apple.CoreMediaIO (703.0 - 4791) <B974A225-61C6-34DD-AC2A-495BD6A393B3> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff8c766000 - 0x7fff8c7f3dd7 com.apple.AppleJPEG (1.0 - 1) <558ACADA-C41F-3EEF-82A0-C2D7B13C5428> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff8cb51000 - 0x7fff8cb7afff libc++abi.dylib (125) <DCCC8177-3D09-35BC-9784-2A04FEC4C71B> /usr/lib/libc++abi.dylib
0x7fff8cb7d000 - 0x7fff8ce13fff libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
0x7fff8ce14000 - 0x7fff8ce39ff7 libPng.dylib (1444) <47ACF98D-B5F1-3A03-B6FD-4107D5FAE5E9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff8cf75000 - 0x7fff8cf7afff com.apple.DiskArbitration (2.7 - 2.7) <F55902AA-5316-3255-A701-FDED5B553065> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff8d268000 - 0x7fff8d296ff7 libsandbox.1.dylib (460.40.33) <26158471-870A-3269-9E2B-7D7963B8E9F3> /usr/lib/libsandbox.1.dylib
0x7fff8d4ac000 - 0x7fff8d4affff com.apple.Mangrove (1.0 - 1) <2D86B3AD-64C3-3BB4-BC66-1CFD0C90E844> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff8d4bf000 - 0x7fff8d4dbfff com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff8d4dc000 - 0x7fff8d550ff7 com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff8d556000 - 0x7fff8d683ff3 com.apple.CoreText (352.0 - 494.11) <08E8640E-6602-3A00-BC28-94235FD311B4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff8d684000 - 0x7fff8d686fff libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
0x7fff8d687000 - 0x7fff8d687ff7 libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
0x7fff8d688000 - 0x7fff8d699ff7 libsystem_trace.dylib (201.10.3) <25104542-5251-3E8D-B14A-9E37207218BC> /usr/lib/system/libsystem_trace.dylib
0x7fff8d69a000 - 0x7fff8d69afff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <054DFE32-737D-3211-9A14-0FC5E1A880E3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff8d6a0000 - 0x7fff8d706ff7 libsystem_network.dylib (583.40.20) <269E5ADD-6922-31E2-8D55-7B777263AC0D> /usr/lib/system/libsystem_network.dylib
0x7fff8d747000 - 0x7fff8d7ddfff com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff8d7de000 - 0x7fff8d7faff7 libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
0x7fff8d7fb000 - 0x7fff8daa1ff7 com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff8e405000 - 0x7fff8e479ff3 com.apple.securityfoundation (6.0 - 55126) <1F6BDF18-3CF0-3E85-8D9B-0663599B9949> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff8e47a000 - 0x7fff8e4c9ff7 com.apple.opencl (2.7.0 - 2.7.0) <307263BA-0368-38C9-A7FB-25920343D0DF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff8e4f7000 - 0x7fff8e503fff com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff8e504000 - 0x7fff8e6b0fff com.apple.avfoundation (2.0 - 1046.9.11) <DE524245-B7EF-3E9D-8AA1-3D99A3304EF4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff8e714000 - 0x7fff8e72bfff libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
0x7fff8e72c000 - 0x7fff8e742fff com.apple.CoreMediaAuthoring (2.2 - 953) <06C2E0E2-BA5C-3BB1-8DD7-55613EDD654D> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff8e743000 - 0x7fff8e744ffb libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
0x7fff8e74a000 - 0x7fff8e752fff libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
0x7fff8e799000 - 0x7fff8e799fff com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff8e79a000 - 0x7fff8eb15ffb com.apple.VideoToolbox (1.0 - 1731.15.202) <B839BE14-9503-3B5E-A54A-C7FCEED34EA3> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff8ecc0000 - 0x7fff8ecdafff com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff8ecf5000 - 0x7fff8ed19fff libJPEG.dylib (1444) <AECB826C-8B14-3D04-8DEC-33EE85F5150D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff8ed1a000 - 0x7fff8ed1fff3 libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
0x7fff8ed34000 - 0x7fff8ed3efff com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff8ee3e000 - 0x7fff8ee56fef libcompression.dylib (28) <E7601B62-1053-369D-8A9E-91CF86239220> /usr/lib/libcompression.dylib
0x7fff8f43a000 - 0x7fff8f43cfff com.apple.SecCodeWrapper (4.0 - 261.40.2) <1F832591-59A8-3B3F-943F-D6D827463782> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff8f48e000 - 0x7fff900b7fff com.apple.AppKit (6.9 - 1404.46) <2492D315-76B6-320B-B542-231FCA44CA48> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff900dd000 - 0x7fff9025bfff com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff9025c000 - 0x7fff9025dfff liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
0x7fff9025e000 - 0x7fff90260ff7 libquarantine.dylib (80) <0F4169F0-0C84-3A25-B3AE-E47B3586D908> /usr/lib/system/libquarantine.dylib
0x7fff902e9000 - 0x7fff902fafff libSparseBLAS.dylib (1162.2) <EBEB3848-3468-342A-91A6-5C47F2369CD9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff90310000 - 0x7fff90334fff com.apple.MultitouchSupport.framework (304.10.2 - 304.10.2) <CE75EDA3-2B22-3968-834E-550EA870ECC8> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff90366000 - 0x7fff90374fff libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
0x7fff90423000 - 0x7fff90473ff7 com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff9053a000 - 0x7fff905eafe7 libvMisc.dylib (563.5) <6D73C20D-D1C4-3BA5-809B-4B597C15AA86> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff905eb000 - 0x7fff905faffb com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff90810000 - 0x7fff90819ff3 libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
0x7fff9082b000 - 0x7fff90b7ffff com.apple.Foundation (6.9 - 1258) <51833143-6CAE-3E1C-9FBA-BCDEB48D4ADF> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff90b9d000 - 0x7fff90ba0ff7 libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff9128f000 - 0x7fff91297fff com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff91863000 - 0x7fff9187dff3 liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
0x7fff91946000 - 0x7fff91999ff7 libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
0x7fff91a07000 - 0x7fff91a0afff com.apple.IOSurface (108.2.1 - 108.2.1) <A0037B0A-277A-393E-9BF6-688595BD564D> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff92696000 - 0x7fff92696fff com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff926b6000 - 0x7fff926b8fff libCVMSPluginSupport.dylib (12.0.40.6) <4AA6710A-6267-3062-BFF2-27DB5E6B5892> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff927a0000 - 0x7fff9282dfff libsystem_c.dylib (1082.20.4) <CDEBF2BB-A578-30F5-846F-96274951C3C5> /usr/lib/system/libsystem_c.dylib
0x7fff929b3000 - 0x7fff92e29fff com.apple.CoreFoundation (6.9 - 1258.1) <943A1383-DA6A-3DC0-ABCD-D9AEB3D0D34D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff92edc000 - 0x7fff92ee0fff libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
0x7fff92ef1000 - 0x7fff93449ff7 com.apple.MediaToolbox (1.0 - 1731.15.202) <A19F9D25-5333-3AA0-90FB-97F3F420A7EA> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff934c5000 - 0x7fff934ffff7 com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff93500000 - 0x7fff938d8fef com.apple.CoreAUC (214.0.0 - 214.0.0) <F80C19CA-6CD0-3052-9C22-0288A257CCC8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff938e0000 - 0x7fff938f9fff com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff93900000 - 0x7fff93a4aff7 com.apple.coreui (2.1 - 366.1) <A3868F31-ACF4-3EA5-9E75-79ED44FA7F06> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff93a52000 - 0x7fff93a56fff libGIF.dylib (1444) <D3F44A33-355E-3154-A465-1C732AAC5F75> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff93ab7000 - 0x7fff93c7dfe7 com.apple.ImageIO.framework (3.3.0 - 1444) <54F18254-F31B-3464-BB51-BAF9E9620419> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff93c7e000 - 0x7fff93c9cff7 libsystem_kernel.dylib (3248.40.184) <88C17B7F-1CD8-3979-A1A9-F7BDB4FCE789> /usr/lib/system/libsystem_kernel.dylib
0x7fff93c9d000 - 0x7fff93ca3ff7 com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff94099000 - 0x7fff940b5ff7 libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
0x7fff940b6000 - 0x7fff940ddfff com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff949bd000 - 0x7fff949bdff7 liblaunch.dylib (765.40.36) <1CD7619D-AF2E-34D1-8EC6-8021CF473D9B> /usr/lib/system/liblaunch.dylib
0x7fff949be000 - 0x7fff949d9ff7 libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
0x7fff94aa7000 - 0x7fff94af9fff com.apple.AppleVAFramework (5.0.32 - 5.0.32) <FC1AED2C-B3E2-31D9-B163-37989CD8A073> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff94dcc000 - 0x7fff94dd8fff com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff94dd9000 - 0x7fff9516efdb com.apple.vImage (8.0 - 8.0) <4BAC9B6F-7482-3580-8787-AB0A5B4D331B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff95215000 - 0x7fff952b9fff com.apple.Bluetooth (4.4.4 - 4.4.4f4) <BCF89EFE-853D-3AEA-AE31-DC8293C7284F> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff952ba000 - 0x7fff95393fff com.apple.CoreMedia (1.0 - 1731.15.202) <D2A49E52-9D26-35A8-BDDC-3BCDBEC5A19E> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff96109000 - 0x7fff961fbff7 libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
0x7fff9623f000 - 0x7fff96242fff libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff963e9000 - 0x7fff9642eff7 com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff965bb000 - 0x7fff965c4ff7 com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff965c5000 - 0x7fff96793ff3 com.apple.QuartzCore (1.11 - 410.14) <0283748A-8318-36AC-8B30-8A951FEB305A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff9679f000 - 0x7fff9679fff7 libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
0x7fff967a0000 - 0x7fff967e1ff7 libGLU.dylib (12.0.40.6) <C56DDF90-CF6D-30D2-A3E6-89288BE69DCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff96881000 - 0x7fff96888ff7 libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
0x7fff968c9000 - 0x7fff968f8ff7 com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff9708b000 - 0x7fff970a8ff7 com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <F4AF2363-B28E-3097-AB1E-FDA1C92F8F56> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
0x7fff970bc000 - 0x7fff970faff7 libGLImage.dylib (12.0.40.6) <734B133F-E789-3A25-9DE6-1CCBA4896D4D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff972da000 - 0x7fff972e3ff7 libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
0x7fff97356000 - 0x7fff976b8f3f libobjc.A.dylib (680) <7489D2D6-1EFD-3414-B18D-2AECCCC90286> /usr/lib/libobjc.A.dylib
0x7fff976e8000 - 0x7fff97788fff com.apple.Metadata (10.7.0 - 972.29.1) <F19E0200-6937-3799-9C67-D26C2CE5AA5F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff977ae000 - 0x7fff977aefff libmetal_timestamp.dylib (600.0.44.1) <6576F284-BACA-332A-A6E7-FA1C347636E3> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fff977c9000 - 0x7fff977cefff com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff977cf000 - 0x7fff977d1ff7 libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
0x7fff97812000 - 0x7fff97875fff libAVFAudio.dylib (161.2) <1A98DBF3-490B-37FB-928A-AB1E36E6E5DD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
0x7fff97876000 - 0x7fff98ac1feb com.apple.CoreGraphics (1.600.0 - 957) <8C9F8E1A-274C-36CE-93FB-49906A9B9EE2> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff98ac2000 - 0x7fff98b13ff7 libcups.2.dylib (435.1) <4198A94D-A46C-39AA-92B6-83D0BA507D6C> /usr/lib/libcups.2.dylib
0x7fff993d8000 - 0x7fff993d9fff libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
0x7fff993da000 - 0x7fff99449fff com.apple.datadetectorscore (7.0 - 460) <8EF4EECC-4FF1-36DF-84CF-65545555A225> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff9944a000 - 0x7fff99452fef libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
0x7fff9945c000 - 0x7fff99494ff7 com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff99495000 - 0x7fff994a3ff7 libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
0x7fff9969f000 - 0x7fff996a7fff com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff996a8000 - 0x7fff996a9fff libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 109432
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=445.6M resident=0K(0%) swapped_out_or_unallocated=445.6M(100%)
Writable regions: Total=55.1M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=55.1M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Activity Tracing 2048K 2
Kernel Alloc Once 4K 2
MALLOC 36.4M 13
MALLOC guard page 32K 7
MALLOC_LARGE (reserved) 1152K 2 reserved VM address space (unallocated)
STACK GUARD 56.0M 2
Stack 8192K 2
VM_ALLOCATE 2180K 3
__DATA 32.8M 298
__IMAGE 528K 2
__LINKEDIT 149.5M 73
__TEXT 296.1M 276
__UNICODE 552K 2
shared memory 12K 4
TOTAL 585.1M 674
TOTAL, minus reserved VM space 584.0M 674
Model: MacBookPro12,1, BootROM MBP121.0167.B16, 2 processors, Intel Core i5, 2.7 GHz, 8 GB, SMC 2.28f7
Graphics: Intel Iris Graphics 6100, Intel Iris Graphics 6100, Built-In
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1867 MHz, 0x80AD, 0x483943434E4E4E424C54414C41522D4E5544
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1867 MHz, 0x80AD, 0x483943434E4E4E424C54414C41522D4E5544
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x133), Broadcom BCM43xx 1.0 (7.21.95.175.1a6)
Bluetooth: Version 4.4.4f4 17685, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM0256G, 251 GB
USB Device: USB 3.0 Bus
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 27.1
Houdini On OSX Crashes From Terminal But Runs Fine From .App
1735 1 0- Adam Davis
- 1 posts
- Enivob
- 2540 posts
You're lucky it runs at all. An 8Gb Mac with 2 CPUs and Intel graphics. That computer does not meet the minimum requirements to run Houdini.
http://www.sidefx.com/index.php?option=com_content&task=view&id=2680&Itemid=390 [sidefx.com]
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
