Slicing up mesh equally without reducing primitive count
   5033   10   1
Hi everyone,
I have a high resolution mesh that I'd like to cut up into smaller pieces while retaining the shape of the mesh.
So take a mesh like this:
Cut it into pieces roughly the size of the highlighted:
To achieve an effect like this:
I feel like I would use the group node here but I'm not sure how exactly to go about it?
Maybe use a lattice of some sort to slice it up?
Okay, scratch that idea. I think with the mesh I'm using I'd rather go in and select/paint the primitives I want to use specifically.
I'm guessing I'd use a group node for each piece…but then how would you animate the primitives in that group?
its jogged my interest , heres your mesh sliced up using abound sop and fracture hope its useful
Rob
Edited by - May 10, 2016 02:30:09
rse_slice_up.hip (1.1 MB)
Gone fishing
you could put the mesh in uv space and cut it up there - then move the pieces back into 3d space.
Training Lead
www.sidefx.com
circusmonkey
Rob
Voronoi fracture, of course! Thank you!
What would be the best way to move the individual pieces?
arctor
Unfortunately I'm still pretty new to UVs in Houdini, what would be the best way to go about doing something like this?
It might actually be easier if I use Maya's Mesh > Extract to do the cutting up, the process is a lot more straight forward and I can export as an OBJ with groups
Since I'm so new to Houdini I'm wondering if it would be easier to animate the pieces separating in Cinema 4D and bringing that into Houdini for particle fx and lighting or to do it all in Houdini.
For instance I want the pieces to move out slightly along their normal, lock into place, then rotate open.
You can definitely do this in Houdini but how would you gather the pieces together so that their rotation can be modified with an effector?
Your going to have to dig around and do exploration on that , I am sure there's something exposed via the cluster point or fracture centroid , try and manipulate one single piece first.
Kind regards
Rob
Gone fishing
something like this :-?
I know, can be done more smart and with chops for animation…
was only a test.
cut_by_uv_island_and_move.hip (327.4 KB)
cut_by_uv_island_and_move_blend.hip (328.3 KB)
Attachment again
matthias_k
was only a test.
Thanks for taking the time to put that together Matthais. I ended up using connectivity and partition with a foreach subnet to achieve the desired effect
