From a long time i am facing Houdini Mantra Error I am having a good graphic card NVIDIA Quadro K2200
Can anyone help me out with the solution of this problem?
As i am Facing the problem since long time.
Houdini Mantra error
1663 3 1- priyank09
- 2 posts
- Enivob
- 2537 posts
- priyank09
- 2 posts
- Enivob
- 2537 posts
Your test scene renders fine on my machine without producing any error.
If you are over clocking or wondering about the stability of your motherboard give Prime95 [mersenne.org] a try. It will stress test your system.
The way it works is you just run it for two hours. If your system stays up and continues to work then your motherboard and overclock are stable. If there are problems they are reported as failed threads.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
