Hi everyone,
I need some guidance on the following. Hope someone can help.
I want to make a simple procedural tree tool which I can distribute over a grid. For every tree I want different size/color/etc. What is good approach in achieving this?
Here my initial thought:
# Create the procedural tree network
# create a null node with a seed attribute
# reference that seed value in the nodes responsible for size/color/etc so that when the seed changes the tree changes
# Create a HDA with that seed value in parameters
# Copy-stamp the tree on the grid with a stamp function in the HDA seed value
Is there another way to do this? Maybe without copy-stamping?
Or maybe someone knows a good tutorial?
how to design procedural tool? important design concepts?
1847 2 0- fredsnyder
- 18 posts
- Enivob
- 2548 posts
Sounds like a reasonable approach. You may want to look into Instancing vs Copying for final deployment.
There is a nice example file here that demonstrates the speed benefit.
http://forums.odforce.net/topic/23294-houdini-16-wishlist/?do=findComment&comment=143811 [forums.odforce.net]
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- fredsnyder
- 18 posts
thanks!
I checked your example. The instance version takes 1.014s to cook and the copy version takes 19.397s to cook. So that's a big difference.
I have very little experience with VEX so i'll probable use the copy-stamp for now; but, once my .hda is finished I think i should be able to do something like this right? (Not sure if syntax is correct :? )
// hda
s@instance = sprintf(“/path/to/hda”);
// seed
float seed = fit(rand(@ptnum),0,1);
v@seed = set(seed);
// hda
// seed
v@seed = set(seed);
