Crash report from martin; Houdini FX Version 15.5.480
Uptime 2 seconds
Tue Jun 28 18:29:14 2016
Caught signal 11
Traceback from 1706 ThreadId=0x7f053a52d200
AP_Interface::coreDumpChaser(UTsignalHandlerArg) <libHoudiniUI.so>
AP_Interface::si_CrashHandler::chaser(UTsignalHandlerArg) <libHoudiniUI.so>
signalCallback(UTsignalHandlerArg) <libHoudiniUT.so>
UT_Signal::UT_ComboSignalHandler:perator()(int, siginfo*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo*, void*) <libHoudiniUT.so>
__funlockfile <libpthread.so.0>
QReadWriteLock::lockForWrite() <libQtCore.so.4>
QGLWidget::deleteTexture(unsigned int) <libQtOpenGL.so.4>
QGLContext::~QGLContext() <libQtOpenGL.so.4>
QGLWidget::~QGLWidget() <libQtOpenGL.so.4>
re_QGLWidget::~re_QGLWidget() <libHoudiniUI.so>
QObjectPrivate::deleteChildren() <libQtCore.so.4>
QWidget::~QWidget() <libQtGui.so.4>
re_QWindowWidget::~re_QWindowWidget() <libHoudiniUI.so>
RE_QtWindow::~RE_QtWindow() <libHoudiniUI.so>
UI_Window::~UI_Window() <libHoudiniUI.so>
QT_Window::~QT_Window() <libHoudiniUI.so>
FUSE_AnonymousStats::~FUSE_AnonymousStats() <libHoudiniAPPS3.so>
FUSE_App::~FUSE_App() <libHoudiniAPPS3.so>
FUSE_HoudiniBinariesApp::~FUSE_HoudiniBinariesApp() <libHoudiniAPPS3.so>
__run_exit_handlers (exit.c:82)
__GI_exit (exit.c:104)
UT_Exit::doExit(int, bool) <libHoudiniUT.so>
RE_OGLRender::initGLState() <libHoudiniUI.so>
RE_OGLRender::makeCurrent(bool) <libHoudiniUI.so>
RE_OGLRender::lockContextForRender() <libHoudiniUI.so>
RE_QtWindow:penWindow(int, int) <libHoudiniUI.so>
QT_Window::doOpen() <libHoudiniUI.so>
UI_Window::handleEvent(UI_Event*) <libHoudiniUI.so>
UI_Queue::processNextEvent() <libHoudiniUI.so>
UI_Queue::drain() <libHoudiniUI.so>
UI_Queue::drainEvents(bool, bool) <libHoudiniUI.so>
OPUI_MainApp::loadFilesAfterUiOpen(UI_Event*) <libHoudiniAPPS2.so>
UI_Queue::eventLoop() <libHoudiniUI.so>
main <libHoudiniUI.so>
__libc_start_main (libc-start.c:289)
_start <houdinifx-bin>
Running Houdini 15.5.480 on Ubuntu 15.04, crashes instantly.
3113 7 0- Adam F
- 51 posts
Trying to run Houdini Apprentice on Ubuntu 15.04 and it crashes before it even loads to the interface. I was able to retrieve the error log, here is what it says. Not sure what this one means actually…
- edward
- 7733 posts
- chrism
- 2494 posts
You should log a bug for that or contact support for help. Thanks!
https://www.sidefx.com/forum/topic/15603/ [sidefx.com]
Chris McSpurren
- malexander
- 5161 posts
- Adam F
- 51 posts
hmmm… trying to get the most updated version of OpenGL on here and it doesn't seem to be fixing the problem. This is a slightly older laptop, so it may not have a new enough card in it to deal with this. Here is what it is running:
VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 02) (prog-if 00 )
Subsystem: Dell Device 040a
Flags: bus master, fast devsel, latency 0, IRQ 27
Memory at f0000000 (64-bit, non-prefetchable)
Memory at e0000000 (64-bit, prefetchable)
I/O ports at 70b0
Expansion ROM at <unassigned>
Capabilities: <access denied>
Kernel driver in use: i915
I/O ports at 70b0
- Adam F
- 51 posts
- malexander
- 5161 posts
- Adam F
- 51 posts
