Hello guys, just started learning Houdini coming from years of Maya, I hope it's not a dumb question but is there an equivalent procedural texture in Houdini like the Maya “ramp” ?
Thank you
Ray
Maya ramp equivalent in Houdini
4018 4 1- madrenderman
- 129 posts
- Innehavaren
- 18 posts
Hi Ray,
there is no prebuild ramp shader, like in Maya.
But there is a ramp parameter, which you can use inside your shader. But you need to plug the UVs or whatever you like to drive the ramp with manually.
So inside your shopnet dive into your shader and add a ramp parameter, as soon you connect input and output the ramp will show up in your shader interface.
Note that it won't show up in your viewport, you need to render it in order to see changes.
Best regards,
Jacob
Here's an example:
Best regards,
Jacob
Here's an example:
Edited by Innehavaren - July 2, 2016 05:05:24
- madrenderman
- 129 posts
Thank you Jacob, the file is very useful, great.
Very similar to Maya ramp, what I miss is the parameter “type” that creates various types of ramps like circular, radial, tartan, etc. and is very useful sometimes I create pupils of the characters just with a circular ramp and three or four colors, and then I animate it using uv coordinates. I'm pretty sure in Houdini it's possible to achieve this and much much more, I have to study a lot !
Thank you
Ray
Thank you
Ray
- Innehavaren
- 18 posts
- madrenderman
- 129 posts
