Hello Houdini guys!
I have problem with caching fluids when OpenCL option is on.
Here is error lines from console
OpenCL Exception: clEnqueueNDRangeKernel (-4)OpenCL Context error: CL_MEM_OBJECT_ALLOCATION_FAILURE error executing CL_COMMAND_NDRANGE_KERNEL on GeForce GTX 750 Ti (Device 0).
I have installed CUDA + Lastest NVidia drivers
I look on About Houdini info
Open CL is enabled.
Any help will appreciated!
Error pyro solver cache when OpenCL option is ON
8302 3 2- ArthurFX
- 13 posts
- anon_user_37409885
- 4189 posts
- ArthurFX
- 13 posts
- animatrix_
- 4531 posts
You have to install a CPU driver and point OpenCL to it using the right HOUDINI_ env variable. Hopefully in H16, it will be a toggle i.e. “Run on CPU” if “Use OpenCL” toggle is enabled.
